Samsung DV210AGW/XAA Dryer, drum wont turn nor heat up
hi all, thanks for your comments. to note, it's my dryer not my washer so the suggested solutions wont work. Also, forgot to note, the unit is only 14 months old and just out of warranty. What I've done so far:
- vacuumed the filter
- striped the dryer, meaning removed top. front and small exhaust panel in the back
- vacuumed everything
- checked the belt, tight, not loose, broken or off the roles
- child safty not enguaged, toggled it anyway to be safe
- the checked micro switch next to belt by motor, not engaged
put it all back, turned on with nothing, tried every setting in auto and manual tied high to low temps and times, the time is noted, such as 40 min, but does not time down, over time, the unit sound the I'm done tone, if left as is, continues to chime then end like it did something. all along, the drum never rotated nor did it heat up.
Does one impact the other, such as if the drum does not roll then the heater wont start or vise-a-versa. Could the control panel have taken a hit or are there sensors that might have shut down to prevent the unit from starting are there fuse's that I didn't see that might have been tripped.
