Kodak EASYSHARE M1063 Digital Camera Logo
Posted on Dec 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset date and time? - Kodak EASYSHARE M1063 Digital Camera
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Kodak Master 102,366 Answers
  • Posted on Jun 16, 2011
Kodak Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10430279
Points
622693
Http://resources.kodak.com/support/shtml/en/manuals/urg00867/urg00867c4s2.shtml
Time/date won't retain
The camera's internal date/time "backup" battery is supposed to maintain the date/time for about 3 weeks with the camera turned off. If the camera is not used for a longer period, the date/time will need to be reset. If you are having to reset sooner than that, it is likely that the internal battery (not user replacable on most models) has failed.
3answers
The time/clock on my computer is 2 hr.s slow.
click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time tab hope this helps
1helpful
How do i reset date after battery change? or where can i cet a pdf file a9no calliber number on case or movement but its a timex perpetual with indigo light approx 30 yers old
to reset the date manually, pull the stem out to the second position to reset TIME; manually continue setting time until the date is on the correct day/date.
I had to do this to get back to the proper date when my timex was off by a week. Nothing else worked. 14 times around (twice per 24 hour day) and each time I passed "midnight" the date advanced.
blessings!
Reset Date and time
yes its possible. Please remove the internal battery once and then put it inside after few minutes. This will reset the date time. while you switch it on once again. it will prompt you to enter new date and time.
Regards
Sweet Rascal
5helpful
2answers
How to reset time and Date?
It must get the date and time from Caller ID when it gets a call. When I first set mine up, the date was 01/01 and time 12:00. Now after receiving three calls, the date and time are correct.
4helpful
Can't find my manual and need to reset the date and time
if system DK series must set at port "00"
#402 to check the port number with displayed phone
#651 DDMMYY - for date
#652 HHMMSS - for time
#653 to change the day
Date & time reset
try and enable automatic update of time and date in the settings..
2helpful
3answers
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
3answers
When the batteries die I have to reset the date and time again in order to take pics! Was there something that I missed or did wrong?!
The manual states that when you change the batteries, you will have to reset the date and time; this is normal operation for this camera (though it is a pain!!!)
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
