Question about Toshiba Satellite Pro 490CDT Notebook
You might have to go to Toshiba support and get a BIOS Flash to update for your BIOS. Win XP is no longer supported, therefore you may need to go to Windows 10.
Posted on Feb 06, 2018
SOURCE: toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS
ESC
Toshiba Protege
ESC
Toshiba Satellite 205 CDS
F1
Toshiba Tecra
ESC then F1 or F2
Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Posted on Nov 04, 2009
SOURCE: i'm trying to help a friend install
After "Fast Boot" has been enabled, you cannot access the BIOS setup
during power on . The machine will bypass "Press F2 to access Setup
Utiltiy and F12 for Boot Menu" prompt.
This is a bigger issue if the hard drive crashes and access to Windows is not possible OR
Fast Boot can be enabled or disabled in the BIOS setup, or in HW Setup under Windows.
If
you have Fast Boot enabled and you want to get into the BIOS setup.
Hold down the F2 key, then power on. That will get you into the BIOS
setup Utility.
You can disable the Fast Boot Option here. You will need to disable Fast Boot if you want to use the F12 / Boot menu.
Posted on Aug 26, 2011
May 04, 2015 | Acer Aspire Computers & Internet
Feb 04, 2011 | Fujitsu AMILO M-6500 Notebook
Jul 06, 2010 | Toshiba Satellite L305D-S5895 Notebook
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Nov 04, 2009 | Toshiba Satellite 1415-S173 Notebook
Sep 14, 2009 | Computers & Internet
May 10, 2009 | Toshiba Satellite U205-S5002 Notebook
Oct 15, 2008 | Computers & Internet
Oct 11, 2008 | Toshiba Satellite A15-S157 Notebook
Aug 01, 2011 | Toshiba Satellite Pro 490CDT Notebook
239 people viewed this question
