Lost Acer password? Try SmartKey Windows Password Recovery software.
In my opinion, the most efficient way is to use some third-party software to reset windows 7 password, and I recommend you to use Anmosoft Windows Password Reset Software, which could help you reset Windows password efficiently. Or you could go to the Acer Official Website to have some questions.
If you lost windows password, you can go into safe mode (F8 when booting up) to recover windows password while you forgot user account password, but if you forgot administrator password, there is no way to change it, you must use software to recover administrator password. Last week, I forgot my Windows administrator password. Finally I use Windows Password Seeker to recover my Windows password successfully. It's worth a try. http://www.passwordseeker.com/howtouse.html
I believe probably the easiest and safest way for you is remove your Windows OS Passwords with Windows Password Recovery tools. I found a good one at http://www.reset-windows-password.com/how-to-reset-windows-password.html last week, and then I downloaded it and used it to remove the lost password within only few minutes. Furthermore, the powerful tool didn't cause a little data lose. It's worth an attempt.
When
you forgot
windows
login password, you
can go
into safe mode (F8 when booting up) to retrieve
you didn't
remember user account password, but
when you forgot administrator
password,
there
is no way to change it, you should
use a
software program to recover administrator
password. Yesterday
morning, I forgot my Windows admin
password. In
the end, I
used Windows Password Seeker to retrieve
the
Windows password successfully. It's worth an
attempt.
For removing Windows login Passwords safely, I strongly recommend windows password program. Few days ago, I downloaded one at http://www.reset-windows-password.com I burned it to a Usb memory card. Booting up and clearing my password within just 5 minutes
I usually used the cheapest and easy to use tools, especialy free trial: like Windows Password Recovery tool 3.0 to reset Windows XP password.
Or you can try hacker. O(?_?)O ~
Forgot Windows password? A Windows password reset bootable disk could do all the job for you, it can reset your forgotten or unknown Windows password safely and quickly without login, you can create a Windows password reset bootable disk with the tool Windows Password Breaker, then use it to reset your password.
SOURCE: Problems with the built in wireless on my acer extensa 5220
Yes, you will need drivers for your wireless card.
You can download them here.
SOURCE: password bios reset Acer extensa 5220 DipSW G39
if ur taking of how to change the bios password...den goto bios setup and reset it...if u have forget the bios password....only by removing the c-mos battery and inserting it again the bios password can b reset..
