Question about Neff 24 in. S5443X2 Built-in Dishwasher
The water not emptying after wash could be due to several reasons.
The filter at base is clogged or the drain hose is clogged or if you have insinkerator (garbage disposal) under sink that may be full.
It would help if you can confirm if the drain pump motor is operating at the end of the wash cycle.
Also try the reset function. Have master switch in ON position. (left most button on door top).
Then press the A & C buttons (1st and 3rd buttons from left on the cluster of 4 button on the right) together for 3-4 secs.
Posted on Dec 22, 2010
Testimonial: "soloution was spot on it was the pump that was jammed . so with elimination we got to the pump thanks ."
