Question about Epson Stylus C86 InkJet Printer
Where can I find a power chord for Epson Stylus C3810?
Posted by sanjibkmukhe on
Carlo Barzo
  • 530 Answers
Go to your nearest EPSON service center and buy power cord for Epson Stylus C86 InkJet Printer. Have a good day!
Posted on Dec 22, 2010
How can I open cartridge holder on my epson stylus photo 1400. It's stuck over on the right and red lights are flashing.
Turn on printer, and unplug power chord while the carriage moving.
Then move carriage by hand freely.
Sep 02, 2014 | Epson Stylus 1400 InkJet Photo Printer
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
How to change the ink for an epson stylus nx130 printer
Replacing procedure only available if one or more ink tank "empty" or not recognized. Follow "how to..." at epson status monitor. but if you wish to replace, just turn on printer, unplug power chord while carriage moving. The carriage released from locking position, move carriage by hand to the appropriate position.
Jan 20, 2013 | Epson Stylus NX515 All-In-One InkJet...
How to open
plug the power chord to the outler and insert also female chord to the printer then >>>push the power on button...that's it very easy
Sep 21, 2011 | Epson STYLUS R230 InkJet Photo Printer
Printer does not switch on power supply and connecting chord OK
Try the connecting power cord on any other device just to make sure that it is working. Check the wall out let and ensure that it is working. If the above is OK then check the main switch on the printer. If it not working then you have to get it replaced. There is no other reason for PRINTER NOT GETTING ANY POWER.
May 01, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Clean clogged nozzles epson rx680.can not move printhead manually
Turn on printer, unplug power chord while carriage moving. Unplug usb. Move carriage by hand freely.
Feb 01, 2010 | Epson Stylus RX680 Color All-in-One InkJet...
Cannot connect printer to computer
First of all you must connect the cable that came with the printer to the computer and power on the printer by plugging the power chord then you need the printer driver software which you can download it from the internet from the website www.driverpool.com by specifying your printer model no later you have to install the printer on your computer
May 28, 2009 | Epson Stylus Photo R320 InkJet Printer
I wish to change unexpended cartridge help ! please.
Unplug the power chord
Open the top cover of the printer.
Remove the print cartridges.
Insert the cartridges back into the printer.
Close the top cover.
Plug back the power chord .
Try printing .
Jan 30, 2009 | Epson Stylus Multifunction Inkjet Printer/...
No power to epson 1280
Well, first things first I guess:
  1. Try the printer in a different outlet (other side of room, or similar, not same power Jack)
    1. If you have power here, your issue is likely the outlet, not the printer.
  2. If the power cord has an "on" LED, check to see if it is lit up while plugged in.
    1. If you have an LED with no light while it is plugged in, you are looking at a power adapter that is no longer working
  3. If there is no "on" LED to check, your next best bet is to take your printer and power cord to a store that sells printers, and ask if you can "try" a new chord before buying it. (most stores will allow this to keep customers happy)
  4. You may also want to check with the manufacturer if the chord is found to be bad, as some will send replacements free of charge.
  5. The last option is that there is an issue inside the printer. This is not likely, though it is possible. Most printers have an external power adapter that keeps any power issue outside of the printer, but I can't tell from the epson site if this printer has one or not. (It would be a black box between the plug and printer.)
    1. This can also be checked by "testing" a new chord at a store. New chord, still no power, internal issue.
      1. If this is the case you will want to contact Epson if the unit is still under warranty.
-Hope this helps.
May 27, 2008 | Epson Stylus Photo 1280 InkJet Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus C86 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Falling star
Kyocera HP Expert
Kyocera HP Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
