SOURCE: CANON IR C6800
Hello Jc.Let me start by saying that despite the fact that you have properly been specific with the error code you have submitted, Canon is "fairly" specific in regards to the amount on detail in provides. I say fairly in really loose terms. The error 602 means that for any number of reasons when the copier went to boot" (begin to start up and read its directions as to what it is, who it is, and what it is capable of, it failed to get the instruction set (or failed to recognize the instructions) and therefore said "what"?!) as the copier sought to retrieve this info from the hard drive.That can mean that the partition of the hard drive that is was looking at contained corrupt information, or there was a communication interruption, or that the hard drive is going or gone bad. I know this sounds like a bunch of technical goblidy gook but you don't want to know what the 0101 means after the 602. It may not be too bad but brace yourself for the worst. That is that the hard drive may have went wheels up, or at a minimum all stored custom information is gone. The latter may be the best you can hope for. I am afraid that a "hail Mary" might be to power the copier of by way of the rear switch (or unplug if you are not familliar) and wait a few minutes.Restart and hope for he best. Otherwise you WILL need a technician to replace the hard drive and then they will have to reload the system software. I was reluctant to respond to your request for help as I cannot "fixya" and I will get a bad grade from the guys that run this site since I left ya hangin. But I could not resist trying to help you and to at least make sure you did not get raped by some "hungry for money" company. Please at least give a decent rating and I will keep my fingers crossed for you..................SPINAL
A E000602-0202 code is a problem with the hard drive booting up. Did you try to reseat the boot rom? You can try a F-disk funcation and they to re install the software from your lap top..You can also try to reseat the HD connections. But, I would say that you HD has crashed and it will need tob replaced. Good Luck
SOURCE: HAVE CANON IR C6800 WITH THE FOLLOWING ERROR CODE... E000001-00ff
It is a Fuser error code .
Could be a poor connection with the draw connector on fixing feeder unit.
Try shimming all three connectors on the fuser draw side can resolve the
issue. Another thing to check is the upper fuser roller for flat spots
this can also cause fuser error codes
SOURCE: CANON IR C6800 FIND THE ERROR CODE E00006-0001
That code is refering to the Fuser Unit being inserted fully. Have you tried pulling the Fuser Unit out part way, then reinserting fully. If this does not correct problem, you may have a pinched wire on the rear Fuser Unit connector. Hope this helps.
