Question about Polaroid FLM-2632 Television
Tv has no power.Fuse is good - Polaroid FLM-2632 Television
Posted by bud101b on
Dehancy Barney
    Master:
  • 691 Answers
If LED not coming on when you plug in red and pressing button blue then it's your power supply. you can order at shopjimmy.com or discount-merchant.com
Posted on Dec 22, 2010
Van Nguyen
    New Friend:
How do I check the power supply of FLM-2632 TV?
Posted on Mar 23, 2013
Tv will not power up
Hi Mike,
You have not mentioned anything about your tv. If it does not power up, it is a simple case of power supply ( inside the tv)failure. Check the fuse if you can, replace it if found burnt. If the set works, well and good. If the fuse blows again, consult someone who can handle your set.
Good luck
Feb 09, 2015 | Televison & Video
Will not turn on, no blinking lights, power coming from cord is good
Sounds like the power supply board is dead. Probably has a blown power line fuse on the board. A power surge will sometimes blow the fuse and protect the board from damage. Replacing the fuse will restore the TV if this is the case. Most times though, the supply has a blown part that causes the fuse to blow and your only option then is to replace the board.
Mar 23, 2014 | Panasonic Tc-42px24 42 in. Plasma TV
Toshiba Model 51H84. Power breaker tripped during a storm. Breaker reset, and TV will not power on. Is there a fuse? Is there a reset button of some sort? How should I proceed? Thanks.
Your TV has a fuse on power circuit board ( that is a standard part).You need to resemble your tv to get the fuse ( make sure to disconnect all power and antenna before doing this service). Usually any tvs use a clear glass cover on fuse ( you can see a small conductor inside the glass). Replace the fuse if the small conductor gets broken. If after the fuse replacement, you got no joy on tv, the receiver part could be get problem also ( due to storm attack) and need to repair / replacement.
I hope the storm only attack your TV fuse.
Good luck
Aug 02, 2011 | Televison & Video
Power supply
As a rule TV Techs will inspect the power supply first. I would certainly see if the fuses are good or bad. Simple?...well yes and no. If you should find a glass fuse and the clarity of the glass internally is clean, no problem.. Now..if the fuse is open and the clarity is clean inside....replacement will cure the TV problem.Repair is still possible. If the fuse is smoky and black internally...major problems, see a tech. If repairs are possible,(good fuse) next suspect a weak power supply and check all grounds, capacitors and resistors. Check voltages if possible. If the power supply is good...and the TV will not operate...could be the signal board. Just a few hints to get you started!
Nov 07, 2010 | Televison & Video
I have a LG 37lc2d and it suddenly turn off and wont come back on, the stand by lights doesnt turn on either. i was wondering if its just the power supply? or how can i troubleshoot this my self to see...
There is a fuse on the power supply close to where the A/C is connected to the board. If the fuse is blown, look at the board and see if there are any burned components and or swollen capacitors. If there are bad components, I would suggest getting a new board.
If the board looks OK, disconnect the connectors from the board but leave in the A/C connector (this way you can isolate the power supply board), replace the fuse, and power up the TV.
If the fuse pops after the power is applied to the unit, then the power supply is bad.
If the fuse is still good, then power off the TV, connect on the main board’s connections, and power up the TV.
If the fuse is still good, then power off the TV, connect the inverters, and power up the TV.
If the fuse blows now, then the inverters and or the panel are bad.
A working power supply will create 5vdc for the main board’s stand by source voltage. This can be found on the power supply at the main board’s connector and it is labeled in black text.
I hope this information helps you.
Good Luck.
May 28, 2010 | LG 37LC2D Television
My screen went black while watching tv a fuse or somthing else?
If your TV makes ANY noise at all while trying to power up(turn on) then your A/C FUSE IS GOOD.
Relay makes a clicking niose when TV is turned on.
Any led that lights up while trying to power up set>>A/C fuse will be good!!!
May 19, 2010 | Sylvania LC420SS8 LCD TV
Element FLX 3211B has no power after 14 months of use. TV will not power on. Checked th fuse near the power cord and the fuse is good. There is no power going to the TV. Tested the power cord and it is...
Took it to a TV repair shop and they did the following:
1. Rebuilt Power Supply
2. Replaced Diode
3. Replacd Transitor
Total cost was ~$100. Tv works fine now.
Mar 13, 2009 | Element Electronics FLX-3211B 32 in. LCD...
My tv did not come back on after a power cut could it be the fuse
Good Day;
After a power outage it is best to 'reboot' the TV. Unplug the TV for 4-5 minutes from a/c outlet, wait, plug back in. Did not work?
It could be the main fuse, it will be located near the a/c cord on the TV's board. CATION!! After removing back of unit make sure the TV is unplugged from the a/c outlet and the fuse will be a glass fuse, ensure that it the correct value eg; 5 amp 250v.
Good Luck and Careful, Big Irish.
Jun 18, 2008 | Televison & Video
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Polaroid FLM-2632 Television Logo
282 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
