Question about Kenmore Elite Oasis 27052 Top Load Washer
Hot water seems to not enter tub during washing cycle. all connections are correct and the hot water hose is hot up to the back of the washer, im baffled ? does the unit start with cold water on the first half and finishes with hot water on the second half of washing ?
honeymokey
    President:
  • 3,113 Answers
They start with hot or warm ,what/ever the setting and rinse with cold water. Check the temperature adjustment and the cycle it's on as some do different things on different cycles.
Posted on Dec 22, 2010
2answers
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
4helpful
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
3helpful
My whirlpool top load washer is leaking out the front side, no hoses are leaking.
Hello there:
Your washer can develop several types of leaks. I will post this solution in 2 seperate posts for you ok?
You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
5helpful
Water is running out inside bottom of mechine
  1. Air gap device: It is a small device found on most washers to prevent the wash water from from being siphoned into the household water supply. It is located either midway along or at the the end of the black rubber hose that comes from the water inlet valve It is usually made of a translucent plastic. If it is deformed or cracked, you need to replace it.
  2. The tube: It is a rubber tube that runs between the water inlet valve and either the air-gap or the inlet spout. If it is broken, it can cause a leak.
  3. Inlet spout: Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If broken or loose, it can cause a leak.
During the drain and spin only:
  1. A washer that leaks only during the spin cycle often has a leak in the main drain hose. Check the entire hose and correct any problem you can find.
All the time:
  1. Hot and cold water fill hoses: Check the hot and cold hoses from the household plumbing. If either hose is leaking, tighten or replace it.
  2. Main tub seal: It is located between the transmission and the outer tub. Open the the machine's main access panel while the machine is full of water with a small amount of detergent. The leak appears at the underside of the outer tub, at or near the center.
  3. Pump: You can probably see the leak when the tub is full of water. If it leaks, replace it.
  4. Outer tub: Steel or plastic outer tubs can rust, split or be punctured. Consult a qualified appliance technician if it is the culprit.
2answers
Ge top load washer leaks from over flow during spin cycle
check your pump it may be partly plugged if it is try to clear or replace pump
1helpful
My bosh is leaking
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Washing machine leaks when not in use
During fill only
All the time
During fill only
All the time
5helpful
3answers
1 beep per second and odd light sequence
there some simple solutions but may not always work but everyone should try. underneath when the water pump engage with the tub. there;s a white plastic clip press it out and turn the water pump. it will come off the tub. before doing this you should have the washer disconnected. have someone or put something under so the washer won;t fell on you while reaching down. sometimes debris gets stucks on the way from the tub to the pump. it insert your fingers inside once the pump is taken out and if you find debris take it out. put back the pump and connect the washer again. this can be a very simple solution it won;t work all the times. but what if it does. :)
4answers
Water problems
If the washer doesn't fill properly, or if only one temperature of water fills the tub, something is probably keeping water from entering the machine or it's draining before the tub fills completely. Set the controls to the first wash cycle, and then try each water temperature setting. If both hot and cold water seem to be entering the washer with good pressure, water may be draining out prematurely during the fill cycle, through siphoning action. Be sure the drain hose's connection to the standpipe is at least 34 inches above the floor (otherwise, discuss the problem with a plumber). An air gap between drain hose and stand pipe that prevents backflow is also good to have. If hot works but cold doesn't, or vice versa: 1) Be sure both the hot and cold water faucets are turned on. 2) Be sure the supply hoses are not kinked. 3) Turn off the faucets. Unscrew the hoses from the faucets and drain them into a bucket. Hold the bucket under the faucets and test them to make sure they both work and have plenty of pressure (see HERE for information on replacing faucets). Screw the hoses back onto the faucets. 4) Unscrew the hoses from the inlet valves and clean the filter screens just inside them; these may be clogged. To do this, pry out the screens with a screwdriver (this can be difficult; the screens may be inside the valves), flush them under running water, then put them back into the hose. If the screens look defective, replace them. Then screw the hoses back onto the valves. Be careful not to cross-thread the hose threads when screwing them back onto the valves. 5) Call an appliance repairperson; there may be a defective inlet valve or a problem with the controls.
Kenmore Elite Oasis 27052 Top Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Vernon Taylor
