Does the power nozzle motor come on? Is it just that the brush won't turn? If it's just the brush not rotating, the belt probably broke and needs replaced.
Is the brush clean? If not, clean all threads, etc. off.
Check all wire connections for breaks, cracks, and discoloration. Power nozzle to wand, wand to wand, wand to hose. If any of those are found, that part, and probably the one it connects to. will need replaced.
Ensure all connections are snug.
Internal wiring, including connections, could be bad. This would include wiring in the power nozzle, wands, hose, or canister.
Reset or hose switch could be bad. These would need replaced.
Power nozzle motor could be bad. Generally the belt will break before the motor burns out, but it's possible it's didn't.
For any internal repairs, including belt replacement, the entire vacuum should be taken to an authorized Aerus Electrolux dealer. The service technician can also troubleshoot and find the problem. This is generally done at no charge.
You've got a great machine, and with proper care and maintenance it should last for years to come.
