Bag will not seal • Check that there aren't any gaps, folds, wrinkles or holes in pre-sealed edges. • Moisture of foods with high liquid content will prevent the bag from sealing properly. Cut bag open and wipe top inside of bag and reseal. • Make sure you've placed the bag in the proper place. When making a bag from a roll, make sure end of cut piece is on Sealing Strip, NOT over Lower Sealing Gasket or in Drip Tray. • Make sure you give the appliance time to cool down. Wait at least 20
seconds between seals.
If all the above have been verified and the machine will still not pull a vacuum, you will need to replace the upper and lower gaskets.
Air is not vacuumed from the bag • Check that there are not gaps, folds, wrinkles or holes in the pre-sealed bags. • Verify that the Drip Tray is inserted properly into the unit. • Make sure the Accessory Hose is not inserted into the Accessory Port. • Check for loose, worn or cracked Upper and Lower Sealing Gaskets. • Foods with high liquid contents may prevent the bag from sealing properly. Cut bag open and wipe top inside of bag and reseal • Check to see if bag is properly inserted into the Drip Tray. • Make sure you've placed the bag in the proper place. When making a bag from a roll, make sure end of cut piece is on Sealing Strip, NOT over
