I bought a pack of 4 at Radio Shack for $3.00.
Sorry, best to take the old one along.
radio shack only has 250v/15amp -- I've tried multiple stores and all say they dont have a 125v/15amp -- do you have the same dimension 4 genius and are you sure it wasn't a 250v that you used?
Just checked. It is 250v, sorry for bad lead. I am searching. Will avise you, if I find 125/15amp..
I found this item at Amazon.com
Slo Blo MDA Series Fuse 125V 15Amp MDA-15
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
Make sure the !!!!capacitor is
discharged!!!!! before attempting any sort of repair.
Check
the door interlock switches first then the high voltage diode with
either an AVO model 8 on high resistance range for short circuit, the
capacitor can fail and go short circuit, the feed fuse on the primary
of the high voltage transformer and then finally, the magnetron is
best checked by substitution.
Hope that helps.
