Maxtor OneTouch II external hard drive 300GB 7,200 RPM - FireWire & USB (E04W300) Logo
A
Anonymous Posted on Dec 21, 2010
Can one tell me if the maxtor ext hard drive runs on 12v ac or dc
Norman Worley
Level 3:
Genius:
  • Master 1,273 Answers
  • Posted on Dec 22, 2010
Norman Worley
Master
Level 3:
Genius:
Answers
1273
Questions
0
Helped
325185
Points
3473
The Maxtor One Touch has a 12V transformer that steps down the 1110Vac to 12V ac and then runs it through a circuit board in the transformer package, that then converts it to 12V dc. That 12V dc (really 14V dc without a load) is then outputted through the attached cord to the jack that goes into the drive. If you look at the data plate on the transformer package, you can discern this information.
A pictoral schematic neg----- C<-----pos appears on the package showing that the shell of the jack is negative while the pos is the inside pin. This is only used on DC applications. Also words on the package say input 110 output 12v dc.
Alun Cox
Level 3:
President:
  • Master 2,679 Answers
  • Posted on Dec 21, 2010
Alun Cox
Master
Level 3:
President:
Answers
2679
Questions
0
Helped
689861
Points
8444
Maxtor personal storage 3100 ext. HD (200 GB). When plug into electrical outlet, the on light does not come on, and when connected to my PC, it doesn't recognize it. I think the power cord is defective....
You can find a power cord for your Maxtor Personal Storage 3100 100 GB Hard Drive here:
http://lcdpayless.com/productpage.php?productId=2503
or
http://www.ecrater.com/p/6553550/ac-dc-power-adapter-maxtor-3100
2answers
I lost the power supply and would like to know what voltage and amps in need in a power supply to operate the maxtor
Power Requirements
AC Input Voltage: 100–240 VAC
Input Frequency: 47–63 Hz AC
here is a link to the manual : http://www.seagate.com/staticfiles/maxtor/en_us/documentation/data_sheets/onetouch_data_sheet.pdf
1helpful
Part No. 9W2874-582
Sata drives use both 5V and 12V power. The standard SATA connector found on most current power supplies carries both. If you're trying to rig up some temporary power just hit your local PC shop and ask for a Molex to Sata adapter that will connect your old power supply to the new drive or pickup a USB to SATA adapter kit as they usually have there own Sata capable power adapter.
Hope this helps FixYa,
Chris
8helpful
2answers
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Lost my AC / DC power adapter for Maxtor 3200 Personal Storage , where can I find one to buy?
The following site guarantees compatible replacement.
http://www.lcdpayless.com/productpage.php?productId=2511
I've been searching for a replacement as well. I found the specs on the original cord at the following site.
http://www.libertye-online.com/servlet/the-1642/new-APD-I.T.E.-POWER/Detail
12V, 2A, positive inner post, 2.5 inner diameter (ID) and 5.5 outer diameter (OD).
I don't think I would buy the exact replacement ADP brand fom the site above. Many have complained about it failing at the 2-yr point. I am considering the following replacement from the same website.
http://www.libertye-online.com/servlet/the-1218/new-Challenger-I.T.E.-POWER/Detail
NOTE: the input AC voltage range is different on this one, but it should still work in the USA.
There are other options on ebay.
http://electronics.shop.ebay.com/AC-DC-12-Volt-/88758/i.html?_npmv=3
Let us know if anyone has specific success with any of these or others.
Conan135
My Maxtor 3200
what was the voltage difference between the supplied adaptor and the one you plugged in by mistake ?
Robert
14helpful
2answers
Power supply details for Maxtor 500 gb, external hard drive and ? manual
The PSU for my Maxtor 500Gb 9NZ2A4-500 drive is 12V DC, 2A rating, 2.1mm "plug" with centre "hole" as positive.
Regards, kbsguru
6helpful
3answers
Top Maxtor Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
