I have an emerson lcd tv but it doesnt have headphone jack and i want to hook up cheap computer speakers. is there a headphone jack i could buy for it or any other way to hook speakers to it without buying an expensive reciever?
Posted by rcosg542 on
sonic boom electronics
  • 1,557 Answers
Simply put .no. the only way of doing this is to have a tech run a line inside the tv to the speakers using a 3.5 mil phono jack with speaker cut off
merry christmas
Posted on Dec 21, 2010
No sound from my Emerson tv
try a dvd to see if sound via the audio/video jacks and also look in set menu to see is speakers are turned OFF or not, the sound if works with a dvd means it is a hookup or similar issue and the audio circuit in the set is good. Also if set has headphone jack see if that works.
Jul 19, 2013 | Emerson LC320EM9 32 HDTV LCD TV
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
We are trying to hook our TV up to our computer to use it as a monitor. What cords do we need to do this besides the normal monitor cord?
if you want audio as well, it will depend on what kind of audio connection your tv has next to the VGA (computer monitor) connection. If it looks like the normal RCA audio, (red and white plugs) you will need to get a male headphone jack (to plug into your computer headphone or speaker out jack) to stereo RCA cable so you would have a headphone jack on one side of the cable and a red and white plug on the other side. Now if your TV just has what look like a headphone jack next to the VGA (computer monitor plug) you will need to buy a male to male stereo headphone jack cable. for both of these, just make sure the cable you get it long enough, or buy an extension.
Mar 21, 2011 | Sansui HDLCD1908 19 in. LCD TV
Can i hook up a headphone to my emerson flat screen tv
yeah you can, from audio out, you can connect your head phone but after plugin an adopter of audio jacks which convert the audio out jacks to headphone pin.
good luck, feel free for more information
do rate if helped
Dec 04, 2010 | Emerson LC320EM8 32 in. LCD TV
Can i hook up my speckers to my tv
yes, all you have to do is plug it into the headphone jack. if your tv doesn't have a headphone jack you can buy an aux jack to the rca input and hook that up. Check out the link below.
3.5mm Headphones Plug Jack to 2 x RCA Audio Cable
Jun 11, 2010 | Logitech Z-5300 Computer Speakers
Using different speakers for TV
If it does not have anything besides optical it will not work unless you have a system capable of optical input (some Logitechs have it, but don't remember which ones, i know that the Z-5500 does certainly have it but that's not too cheap).
Weird that it doesn't have a a headphone jack indeed. But if it doesn't, that optical digital out is the only way to connect it.
Jul 02, 2009 | Televison & Video
My headphones wont work with my emerson lc320em9 tv jack on headphones is to large to fit into audio out jack ontv
i suppose you want to connect a 6.3mm jack (very big stereo headphones) to the 3.5mm connector on the tv ... google for >> 1/4" Stereo Jack to 1/8" Stereo Mini Jack Adapter
Jun 13, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Headphone jack is weird...
HAVE YOU TRIED THE BEST QUALITY HEADPHONES LIKE SONY AND DID YOU CHECK YOUR COMPUTERS VOLUME?
Mar 25, 2008 | Logitech Z-5300 Computer Speakers
Televison & Video Logo
211 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
