Question about GE Refrigerators
I have a GE Profile GSL251FRF BS. For the past week a high pitched squeal/sqeak is heard when the motor is running. What is that and what's the fix?
marka19
    President:
  • 1,430 Answers
This is likely one of the fan motors. If it is coming from the lower back it would be the condenser fan and if it is coming from the frezzer compartment it is the evaporator fan. Both are inexpensive and easy to check and replace. Here are a couple links that should help
Condenser fan replacement
Evaporator fan replacement
Posted on Dec 21, 2010
Marat Brikov
    Director Badge:
    Uploaded 100 video answers.
  • GE Master
  • 513 Answers
sounds like Evaporator fan motor is going bad. Here is The video how to replace it
Posted on Jun 27, 2015
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
When i run my GE Clothes Dryer, It has a high pitch squeak How can I fix this
remove the front panel inside there is what is called the top door bearing,its probably worn through the drum slides and into the plastic bearing creating this squeal part # WE3m26
Feb 10, 2013 | GE Dryers
How do I fix a high pitch noise when spinning?
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings.
Jan 28, 2011 | Asko W6222 Top Load Washer
My Microwave continues to run unless door is open. I do not think it is heating though when I shut the door. When I close the door and push buttons nothing happens. I get a high pitched sound when I...
The high pitch sound to me may be coming from the speaker on the main circuit board. Try to unplug for a few minutes, reset clock time and then try again. If same issue, may need new PC board. When you say Microwave continues to run are you meaning the Turntable is turning and the fan running?? Or is it just timing down. Almost never does it actually keep heating. On GE units I mostly find bad door switches will cause a back feed and make the tray turn and the cooling fan for the mag to run. To see if that is the problem You have to look at the door switches behind the front panel on the left side and see if any of them have any browned connections on the terminals where they push ontl the back of the switch. That will cause the fan and turntable toi run, but wouldnt cause a high pitch squeal. These companies use switches wtih small 3/16 terminals that dont give a good enough grab on the switch, they get loose and hot and make the switch go bad. I replace that switch with a switch with 1/4 inch terminals and runa short section of Hi temp wite to it and it wont go bad again. Just cheaply made!! Also I guess the squeal could come from the turntable motor area. So By fixing the switch problem it could fix your squeal. With nothing else running you may be able to hear motor and coupling noise you couldnt hear before.
Aug 17, 2017 | GE XL1800 1100 Watts Microwave Oven
Our water softener makes a high pitched squealing noise every 10 min. or so, and then quits for several hours only to start again during the night when we're trying to sleep. Our water softener repairman...
A softener will generally make a high pitch squeal when it is backwashing. This is generally the first cycle in most softeners. It may also do this during the final fast rinse cycle. The second brining cycle takes about an hour. That is why you may have a delay in the squeal. Also I have seen at times when a power surge can force the drive motor into a short backwash. Usually just a few minutes. It may help to put a surge surpressor at the water softener plug.
RJ
Aug 22, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Squeeks loadly when running
The drum belt is slipping or a support wheel bearing is worn.  Spray some belt dressing on the belt or replace the belt.  Lubricate the wheel bearing or replace it.  It is also possible that the seal between the drum and the housing (at the back) is worn and the drum is rubbing metal-to-metal on the housing.
May 28, 2009 | GE Profile Harmony DPGT750EC Electric...
New High Pitch sound
If the sound is from the compressor, the unit is likely under warranty...generally 5 years.  If the unit is frozen up and the sound is from a fan that is hitting ice, defrost the unit completely.  Other fans in the unit could also be squealing.  You'll have to be a detective.
Nov 20, 2008 | GE GSS20IEP Side by Side Refrigerator
High pitched whine
I have the same problem. Replaced the module and still a continous beep....
Dec 28, 2007 | GE 24 in. Profile PDW9880JSS Built-in...
Refrigerators Logo
503 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
