Question about GE 24 in. GSD4020Z Built-in Dishwasher
GE potscrubber 1000 dishwasher wont start..repair man says it is the starter and is too old to find a replacement part (1988 model) It works great otherwise. (or did work until yesterday)
5 Suggested Answers
Anonymous
  • 38 Answers
SOURCE: GE Potscrubber Disshwasher GSD700G, wont cycle
Most washers do not fill they spray the dishes. When enough water has accumulated in the bottom a float switch shuts off the water and turns on the pump to remove the water. If the pump motor does not remove the water the cycle will not continue but the timer will. There may be something clogging the pump and resulting in an overload condition for the motor. This would account for the smell. A pump may turn freely when you spin it by hand because you cannot spin it fast enough by hand to determine if the pump is obstructed. Does the cycle drain the water? If the cycle stops and there is water in the bottom not being pumped out then you should look at the pump and the motor to determine problem.
Posted on Jan 19, 2008
Dave Harrison
  • 114 Answers
SOURCE: ge potscrubber 640 dishwasher
You probably have a restricted water inlet valve. It is not allowing the proper rate of flow for the allotted time, therefore not giving enough water to create the proper velocity to reach the top rack.
Posted on Feb 19, 2008
Anonymous
SOURCE: GE potscrubber 700
upc leaks when dishwasher is emptying
Posted on Sep 03, 2008
Anonymous
SOURCE: Dishwasher Timer won't advance
my timer has stopped functioning altogether. it was first an intermittent problem, but is now 100%.
Posted on Jan 02, 2009
Erica
SOURCE: GE DISHWASHER LEAKS AT LEFT CORNER
Have the same dishwasher and happens sometimes to mine when the door doesn't close properly because it is hitting the cabinet front. Try pulling up and forward from the bottom of the door when it is closed. if the bottom comes forward this could make the difference and stop the leak.
Posted on Jan 26, 2009
Ge potscrubber 940 dishwasher
My GE potscrubber, model GSH942 (very old) is not working, as one of its part was fumed (burned). Though the dishwasher is old, it was doing perfect job. Kindly advise whether there is any hope to save it. picture of damaged part is attached.
664ecbc5-d293-4bf8-9a26-d4eb60b56c88.jpg 3afc25c1-d149-45c7-8546-1d01d256fcd6.jpg 2ffcde17-d805-44d2-865f-843483703dd0.jpg
Aug 10, 2013 | Dishwashers
Looking for dishwasher manual for Model Number GSC700X01AD. GE Potscrubber 700
is this the manual your looking for http://www.managemylife.com/mmh/owner_manuals/4241/GE-Dishwasher-L0801045?brand_name_search=GSC700X01AD+GE+Potscrubber+700+ if you have any further questions or feel that this is not the right manual message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to help others in similar situations in the future Thanks Rick
Feb 13, 2011 | Dishwashers
I have an older GE potscrubber 1000 and it looks like mold is collecting in the bottom. Dishes are not getting clean. Can I take apart the stuff on the bottom to clean it all? Why would this be happening?
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Nov 03, 2010 | Dishwashers
My GE Potscrubber 2230 is not heating the water in the dishwasher. The water at the sink is hot but when I ope the dishwasher, the water is closed. Sooo, it's not cleaning the dishes. Is there something...
Check your heating element..
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 18, 2010 | Dishwashers
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
GE Potscrubber Dishwasher Stuck on Cycles
Could be a defective cycle timer
Jan 30, 2018 | GE Dishwashers
Water not draining
For starters does it drain at all?If the drain line is connected to the sink drain and you have a garbage disposal,the drain hose could be plugged up.
Aug 06, 2008 | Dishwashers
Dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Jun 18, 2007 | GE 24 in. GSD2600GBB Built-in Dishwasher
Open Questions:
See all GE 24 in. GSD4020Z Built-in Dishwasher Questions
GE 24 in. GSD4020Z Built-in Dishwasher Logo
275 people viewed this question
Top GE Dishwashers Experts
Mike
Vitally Alcher
Nathan Van Boven
Nathan Van Boven
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
