Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Posted on Dec 22, 2010
Oct 24, 2014 | Kodak ESP C310 AllInOne InkJet Printer
Jun 30, 2014 | Kodak ESP Office 2150 All-in-one Printer
May 16, 2017 | Kodak ESP Office 2170 All-in-One Printer
Jan 31, 2018 | HP LaserJet 5000n Printer
Top
Paper jams inside the printer
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
To manually remove paper pull on the paper with both hands being
careful not to tear the paper while pulling it. If you're unable to get
to an edge of the paper that allows you to pull it you may need to
manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As
mentioned earlier it is inevitable that you will encounter at least one
paper jam during the life of your printer. However, if you're
encountering frequent paper jams following the below steps can help
prevent paper jams from occurring.
Oct 04, 2010 | IBM Infoprint 1332 Laser Printer
Oct 02, 2010 | Office Equipment & Supplies
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Jun 22, 2009 | Canon PIXMA MP600 all-In-One InkJet...
1,019 people viewed this question
dont see any paperpaper jam
