Question about Vacuums
I have a model 605d ,the machine work fine except it will not sew! i look over the machine it look ok ! i am found out that top spool thread and the bottom bobbin thread are not coming together to sew!
Irene Tulloch
  • 498 Answers
You have to do the first stitch using the handwheel so that the top thread catches under the bobbin thread and then you can pull the top thread which will bring up the bobbin thread. put both threads to back of machine. Now you can sew.
Every time you re-thread you need to do this.
Posted on Dec 21, 2010
How can i do reset to my sewing machine?
It sounds as though something is caught or not put in correctly. Make certain that the thread is coming off the spool smoothly. You didn't mention if you can sew while it is beeping. Check your manual or contact any Singer sales center to question the beeping.
Dec 23, 2013 | SewShop.com Singer Model 7446 Instruction...
Royal Series, Necchi, Model # 80331763 bobbin does not take up thread properly. No manual unsure if i am threading it correctly.
You can get Necchi instruction manual from Necchi website: http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Sewing_Machines.htm". Makesure the needle is in the machine correctly- all the way up into the needlebar, make sure that it is threaded correctly, etc. If this all checks out ok,take the bobbin case out of the machine. There are two ears on either side ofthe bobbin case- turn the left one to the left and the right one to the right.Remove the silver ring, and inspect the piece of metal that the ring came off of(looks like a circle with the top cut off). You have to locate the hook whichis the piece that looks like a half moon inside the big round metal piece.Locate the tip of it, turn the hand wheel toward you until the needle is in thelowest position, at this point the tip of the hook should be flush with top ofthe left side of the cut off circle. Checkwhether underneath thread is looping on the fabric. If so then you've mis-threadedthe top, probably haven't raised the presser foot when threading so you can getthe upper thread into the tension. You need to thread the upper part with thepresser foot up. (You can put it down to thread the needle.)
Not picking up thread can be several issues, like bobbin is miswound, bobbincase isn't snapped in properly, you're using the wrong type bobbin, machine isout of time, needle is bent or burred, machine is dirty and in need of dustbunny eviction and a little oil but most of the time the issue is once againmisthreading: sewing machine needles have a front and a back and they have tobe placed in the needle holder correctly. In that case your manual is needed, take all the thread offthe machine (yes, spool off the spool pin, bobbin out of the bobbin case), pullthe needle plate and clean your machine thoroughly, using brush and vacuum (notcompressed air) and oiling per the instruction manual. Put it all backtogether, putting in a 80/12 needle, correctly oriented. Hang on to theneedle thread when you fetch up the bobbin thread.
Each and every seam you start is going to be done this way:
1) Pull the tail of the top and bobbin thread behind the presser foot
2) Put the work under the needle and use the hand wheel to lower the needleinto the work
3) Drop the presser foot
4) Holding the thread tails behind the foot, take a couple of stitches.
5) Drop the thread tails and sew normally. Hope this will help you. Good Luck.
Sep 12, 2011 | Vacuums
Hi, I have a silly question. How on earth do I thread my Brother Xr-65 sewing machine?!! I have misplaced the users manual during my recent move. It seems to take thread a little differently than my...
The XR-65 and the XR-65T are the same except that the T indicates the sewing machine was sold with the Quilting Table and some accessories for quilting.
To thread the sewing machine, first lift the presser foot and use the handwheel to raise the needle to its highest position. The thread take up lever should be at its highest point. Place the spool of thread on the horizontal pin secured with the appropriate cap. Make sure that the thread comes off the spool from the bottom front, (Also check that the catch (for holding the thread when not in use) on the spool is at the back of the pin.) Then bring the thread to the thread guide at the back of the machine then down past the reverse lever and back up the the thread take up lever. Wrap the thread around the take up lever so that it slides into the slot and then goes through the hole in the take up lever from right to left. Bring the thread down again and place it behind the guide above the needle. Then thread the needle from front to back.
Brother has the manual available for download: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000061/xr52c65txl64526562ug01enesfr.pdf . See page 31 (43 of the PDF) for the pictures of the upper thread path.
I hope this helps.
Jul 29, 2011 | Vacuums
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
It's been years since I sewed anything and now I can't seem to get the bobbin to thread properly, I've tried several ways and none work. Help please
This is a picture of typical bobbin threading. The thread should go around the bobbin and come out through the slot in the same direction...see B1. The thread goes from inside the bobbin through the slot to the outside of the bobbin case. The screw adjusts the tension on the thread as it comes out.
If you mean how to thread it to wind the bobbin we'd need to know what model and brand of machine you have as they're a bit different in how that's done. In older machines it was often on top, sometimes towards the back of the machine towards the wheel. The thread went through several guides and it wound the bobbin only when you pushed the spool post that held the bobbin up against the wheel that caused it to turn, after releasing the hand wheel on the back so the needle wouldn't go up and down as it wound the bobbin.
May 03, 2011 | Singer Vacuums
I just got a new machine (new to me anyway) new home hf106 model. i need to thread the bobbin on the new thead i am using and am not sure where to put the empty bobbin and how to thread it. help!
Janome New Home?
Unfortunately, Janome doesn't put the manuals for older machines on their website. Your best bet is to contact your local Janome sewing machine dealer and ask for a "copy" of the manual from them. A photo copy should be sufficient for your purposes. Otherwise I understand you'll have to buy a manual and wait to have it shipped.
But carefully look at your New Home. On the top toward the right there should be a fitting that looks like the bottom half of a spool. and next to it is a thing that almost looks like a mushroom.
Put the spool of thread on the spool holder, run the tread to and around the tension discs on top then thread the end through the hole in your empty bobbin. Place the bobbin on the thing that looks like a half a spool and push the whole thing to the right toward the "mushroom."
Press start, or hit the foot feed. Wind slowly for best results.
When full, stop and move the bobbin winder back to the Left (sewing mode)
Now... hold your bobbin between your right thumb and fore finger... pull the thread a few inches... your thread should be coming off the LEFT side of the spool, if not flip it over and try again. Open the bobbin area, drop it in with the thread coming off the left to the bobbin.
hold bobbin still with right index finger and with left hand slip the tread between the bobbin race's tension spring then if your model has a channel for the tread... follow it... otherwise pull straight back, replace the bobbin cover on the machine.....
Thread top thread then use the hand wheel to take up the bobbin thread.
(Of course this all assumes your New Home is similar to my janome or brother.) Have fun!
Be sure to get some good needles.... ;)
S
Mar 12, 2011 | Vacuums
While using the pin stitch , the machine has started skipping stitches, knocking loudly, the top thread is breaking, sometimes thread knots up on the underneath side. I have cleaned bobbin area, changed...
Please go through the link given bellow to have the resolution to your problem...
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Apr 27, 2010 | Vacuums
Sewing machine won't pick up bobbin thread
open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Jan 05, 2009 | Vacuums
With my K6 Industrial Singer sewing machine the top thread seems to be too tight. The bottom thread is looping too much on the top of the fabric. The timming is ok. I have checked and rechecked that I have...
Hello there, loosen your top thread tension,if it looping on top of the material the tension is way too tight, you will also find changing the thread size to smaller thread, the top tension will also reduce,depending on application a good size thread to use is 25 grade,bobbin tension should have just a slight amount of drag as the top thread and bottom work against each other when sewing.
regards
Tony
Apr 04, 2008 | Singer Vacuums
Vacuums Logo
99 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
