My 03 x type jag wont even try to turn over? Dash lights are fine but windows, mirrors and starter dead! All the dash lights and monitor and radio work but wont even tryto start? Transmittion wont come out...
Sounds like all of the high drain devices are disabled due to a weak battery. You are still getting dash lights and radio because they are very low drain devices. Try charging the battery to test for now. It could be a failing battery, or your alternator and or voltage regulator could be going out and not charging the system. But first, try to charge the battery, and see if you can start it, if you can, let it run for at least 10 minutes. If your alternator/VR is going out or is already out, you should have a guage, or idiot light telling you that you have low voltage. If its a light, you should see a red battery lit up on the dash, if its a guage, it should be directly in the middle +/- a little. If you are able to run the vehicle for a while with no light coming on, or guage showing low voltage, its safe to say you drained the battery, or it is failing. If its a few years old or more, i'd go ahead and replace it. Hope this helps :)
