SOURCE: Shuttle Jam problem in printing through printronix p5005b
You might want to check your gap indicator. If it is turned to A put it on B or C. Then try printing.
If you have any other questions of needed parts or ribbons for your unit I am an ASR for printronix and carry new and used product. Please contact me.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
[email protected]
AOL IM: RORYMRP
SOURCE: "Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
SOURCE: PRINTRONIX P7-500 LINE PRINTER SHOWS
it means Barcode detected, but not fully
decoded.
check If barcode appears to be damaged, then reverse ribbon spools. If barcode label is present and undamaged, clean sensor lens using damp cloth or swab.Check that platen gap may be too tight constricting ribbon motion. Loosen gap if needed.
