Question about Sony RDRGX210S DVD Recorder
Cant turn off progressive scan with remote for a sony RDR-GX210
Posted by ashflash20v on
5 Related Answers
Anonymous
  • 319 Answers
SOURCE: Not able to turn off Progressive scan feature-sony dvp nc85h
Are you pressing the Progressive Scan button on the front of the Player? You need to look at the BACK of the Player. There is a manual switch just below the words "LINE OUT". This needs to be moved to the left where it says "Normal"
Try this please!
Brian
Posted on Jan 08, 2008
SOURCE: LG vcd player
trata esto prende el dvd saca el disco de la charola de carga despues presiona la tecla STOP por 10 segundos a ver si esto desactiva esa funcion suerte.
Posted on Apr 09, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: cant turn off progressive scan
Press OPEN/CLOSE on the DVD player
to open the disc tray.
Press numeric keypad ‘1’ on the
remote control for few seconds.
➜ The DVD blue background screen
will appear on the TV.
Posted on Sep 04, 2008
Anonymous
SOURCE: progressive scan mode
THis one should be easy--just read it in the manual--reset your video mode by removing any disks from the player, close the drawer, and then press and hold the "stop" button for five seconds. The green power button should flash red and back to green. Hope that solves it.
Posted on Sep 20, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: A Sony RDR-GX210 DVD player I can play a CD -
Hi Allan,
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
In your case the lens does not work on DVD , but only on CDs for the reasons above , that is quite common.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Posted on Sep 08, 2009
Testimonial: "Haven't tried it yet - but will let you know if successful thanks - Allan"
I want to blackberry 8520 service manuel pls sent me
Here it is: http://homepage.ntlworld.com/kingjohns-guides/guides/sony-rdr-gx210.html
Mar 01, 2011 • Cell Phones
3answers
Sony rdr-gx210 only plays cds
When that happens it means you have to clean the lens.
Want to play region 1 dvd on my sony rdrgx210...???
Try this: http://homepage.ntlworld.com/kingjohns-guides/guides/sony-rdr-gx210.html
RDR-GX315 was accidentally reverted to "Factory Settings" ... now we can get sound but no picture and progressive is turned on and we need to turn it off.
If your TV has progressive scan capability, you may be able to view the on-screen setup menu via the recorder - select 'SETUP' press 'ENTER' on your DVD recorder's remote to bring up the menu - with the remote arrow buttons, scroll down to select 'VIDEO' then 'PROGRESSIVE' - highlight it then set it to OFF (you cannot do this with a TV that does not support progressive scan from this unit). Once done, exit the setup menu and it should work fine with all the other settings. If your TV doesn't have progressive scan, connect the DVD recorder to one which does and turn its progressive output off there. I assume you still have the user manual for your recorder (if not, you can download it online for free as an Adobe document - .pdf. Page 73 details the setup steps for this model). I hope this tip helps somewhat.
2answers
Sony DVD Recorder
I have a Sony RDR-GX7 That stopped recording & playing DVD's
2helpful
2answers
RDR-VX515 IN PROGRESSIVE MODE
just press and hold the pause key on the unit for about 5 or 6 seconds and the progressive mode light will go off and the picture will come back.
4helpful
2answers
If it works like my sony RDR-GX315 just press the pause button on the player itself and hold for 5 seconds.
2answers
I'm stuck in Prggressive Mode on my RDR-VX515
pressing and holding the PAUSE button on the front of the DVD player for 5 seconds. (this is the one that worked for me) Hurray!
pressing the PROGRESSIVE button on the front of the DVD player or P.SCAN button on the remote control to disable the progressive signal.
power off the DVD player and press 369 using the number buttons on the remote control, then power back on the DVD player.
moving the VIDEO OUT switch on the back of the DVD player to the INTERLACED position.
1helpful
2answers
Sound but no picture
Apparently your TV doesn't support the progressive mode (480p). You should be able to turn it off by pressing the pause button on the recorder for about 5 seconds, untill it turns off I guess. Hope it works
Sony RDRGX210S DVD Recorder Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
