SOURCE: Emachine T1840 Sound, Ethernet, & Usb Trouble
I had the same problem. The drivers on the manufacturer's site did not work. Only the original drivers on the CD that came with the motherbaord.
SOURCE: Hello, I just got this
I have been unable to find the drivers for this particular board you should go to http://forums.driverguide.com/ and request the file as it is not hosted anywhere currently I hope that someone still has their driver disks and uploads the files for you
SOURCE: I've replaced the hard drive
You need to reinstall the drivers for your network adapter, sound, etc. You can run them from your original support cds if you have them available. Please see this excellent tutorial for guidance in correcting this error. Also of help may be this link.
If you work through that and still need assistance, write back with the results and we'll be happy to help you sort it out!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: I just installed windows xp on a emachines model
You actually don't need an executable or a setup file to install the driver. When you unzip the set of files, put them on a location on your C:\ drive where you'll know your'll find them like c:\drivers\ethernet (just as an example) Go into device manager and under the device driver for the ethernet controller, right click and then go to "Update Driver." When you get the Hardware Update Wizard, select, "No, not this time" and choose "Install from a list or specific location." Check the "Include this location in the search:" and then browse to the directory where you extracted the files.i.e c:\drivers\ethernet\ and click next until the wizard finishes installing the driver.
I hope that makes sense if you need further clarification please reply back to this post. Please don't rate me until I help you resolve your issue. I will help you resolve it.
