Question about HP LASERJET P1006 Printer
How to solve paper jam for HP laser get p1006
Posted by aaom_04 on
Brandan Heasley
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Use Premium paper. It is a little bit more expensive, but it will reduce the amount of jams that occur
Posted on May 31, 2019
5 Related Answers
mbase213
Mark Taylor
  • 728 Answers
SOURCE: PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Note
    • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
    • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
  1. Pull the paper tray completely out of the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Press the cover release button and then open the front cover.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
    After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
    Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
hl50_047.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
  1. Close the front cover.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Posted on Apr 04, 2009
Anonymous
  • 58 Answers
SOURCE: hp p1006 wont load/feed paper
Mine does the same thing. The solution I have used on several occasions is to load it as full of paper as possible without forcing it under the guides. Lift the lid to reset the jam function, then when it begins to try to print, push the top one or two sheets of paper into the printer. If it will grab them and print then it will be ok for the whole stack of paper. Adding more paper before it gets too low also seems to help.
Posted on Jun 05, 2009
Anonymous
SOURCE: HP laser jet 3055 document feeder jam
document feeder jam
Posted on Jul 27, 2009
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
SOURCE: paper jam in hp laser 1320
Unplug the power cord and open the cover and remove toner and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Posted on Feb 10, 2010
Walid M Sayed
  • 313 Answers
SOURCE: hp laserjet p1006 isn't recognized by computer
you may have a problem in your formatter board
Posted on Apr 03, 2010
Hp laserjet 1005 printer second page paper jam
Hi senthil, my name is Lisa and I would be happy to help you with your Laserjet 1005. I understand you are experiencing a paper jam when printing multiple page documents.
There are multiple variations of the 1005, below I will list 3 links one for each of the 1005 Laserjet printers I think you could have.
Clearing Paper Jam for HP LaserJet P1005 P1006 P1007 P1008 and P1009...
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=1839458&docId=emr_na-c00765431&docLocale=en_US < HP LaserJet M1005 MFP - Clearing jams
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=bpl10965 < HP LaserJet 1000 Product Family - Clearing Printer Media Jams
I hope that one of these links is specific to your printer, and that the appropriate link helps you resolve the issue.
Best of luck. I work on behalf of HP.
Jul 02, 2015 | HP Office Equipment & Supplies
Paper jam and we cant see the paper
open toner door pull out the toner ,now remove the paper.
May 25, 2015 | HP LASERJET P1006 Printer
My HP color Laser Jet 2600 printer has a paper jam
Jul 21, 2014 | HP Office Equipment & Supplies
My HP Laser jet P1006 will not print. when I click printer and faxes on my computer it is showing me that I have a paper jam. I have checked the printer and this is not the case. The computer has allowed...
1) open printers and faxes.... right click on the printer icon... click on pause printing... and then click on cancel documents.... when that is cleared... right click and delet the printer icon while u have the usb cable unplugged... once that is gone... plug in the usb cable... wait for few seconds and then try to print....
2) if u are not able to delete the printer icon by following the above step... click on start and then run... type in services.msc and hit ok.... in the services window stop the service called print spooler and then start it again.... and then follow the step 1... it should get deleted
3) even after completing the step 1 and when u try printing... if u r getting paper jam error message then thoroughly look for any jammed paper... even a small piece of paper will cause this problem... so check out thoroughly... and if u dont find any... reset the printer by following the below link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01174212&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=3435684&lang=en
you can also go through the following document
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01179923&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3435684
Mar 18, 2011 | HP LASERJET P1006 Printer
My hp printer says there is a paper jam and there is not any paper in it
There is a small piece of paper stuck under the sensor at the rear of the input unit.
Oct 01, 2009 | HP LASERJET P1006 Printer
Printer problem
even a very small piece of paper (A small piece torn off a jammed sheet) can cause the sensor arm to stick in place giving a false paper jam. Double check the entire paper path (what is visible) using a flashlight.
Also, check for broken "flag" sensors. Basically a flag sensor is a small piece of plastic that is pushed out of the way when the paper is traveling through the unit. If one of these flags is broken it may display a paper jam error as well (The flag after paper travels through will drop back into the paper path.) If this is broken it will not trigger the sensor and thus the error condition exists..
Most likely you have a small piece of paper stuck inside the paper path somewhere.
Do not, I repeat do not use any sharp or pointed metal objects to remove any small paper from within the fuser unit, the fuser covers are very delicate and such poking and prodding will likely damage the fuser covers, causing bad print quality or drastically decrease the fuser life (a small tear will quickly render the fuser useless).
Hope this helps!
Aug 31, 2009 | HP Office Equipment & Supplies
Hp p1006 wont load/feed paper
i know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
3)IT WORKs
If i helped you please rate me
Dec 10, 2008 | HP LASERJET P1006 Printer
HP LASERJET P1006 Printer Logo
246 people viewed this question
Ekse
efs_perpends
efs_perpends
