Samsung SCX 4521F All-In-One Laser Printer Logo
Posted on Dec 21, 2010
I have installed printer on vista pc and share it. when i give print from another vista pc i cant print. but when i print a test page from vista pc after then i am able to print. i cant understand the problem.
5 Related Answers
Anonymous
  • Posted on May 29, 2008
SOURCE: printing prob while adding printer on sharing basis
Hai
I have a SAMSUNG SCX-4100 Printer which is not working even though printer is installed to the system the message is appears as " WINDOWS CANNT CONNECT TO PRINTER, THE LOCAL PRINT SPOOLER SERVICE IS NOT RUNNING. PLEASE RESTART THE SPOOLER OR RESTART THE MACHIN. Please suggest in this regards.
Neelesh Agarwal
Anonymous
  • Posted on Jan 31, 2010
SOURCE: I can't print from Internet Explorer 7 with my samsung clx-2160
Hi you've probably worked this out long ago but it's not the printer that's the problem, it's IE7. You need to right click on the IE icon on your desktop and click 'run as administrator'. There are other settings in IE7 that you can change as well if this doesn't work.
Anonymous
  • 253 Answers
  • Posted on Apr 05, 2010
SOURCE: white photocopy is
re set it with service mode
Anonymous
  • 3 Answers
  • Posted on Jul 21, 2010
SOURCE: samsung clp-315 printer stops printing after half page
i have samsung colour printer. half page printing then stop the printer. after turn on the printer the balance page automatic take out
Anonymous
  • Posted on Nov 30, 2010
SOURCE: i have riffile my smasung ml-1640 printer cartage
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
1helpful
2answers
Printer does not give test page print
Check the right corner of the cover,you will see a pointing plastic touching the sensor,check if its broken then replace it,if you cant,then you need to replace the whole cover,,,
1helpful
2answers
My ml 1610 printer says its not connected to my computer even though the cord is pluged into the usb port
Check the hardware and software settings first
1) Check the Hardware Connection -
a) Power connection to Printer
b) USB Connection from Printer to Computer
2) Checked the Drivers Software
a) XP/Vista = Open the device manager
Click Start - right click on My Computer
Click on Manage
Click on Device Manager
Click on (+) Ports COM & LPT and Check Printer is listed or not
or
Check for Printer Name (Samsung ML1610) is it listed under device manager
if YES - Check by printing the test Page
if NO - Install the Printer Drivers and then print the Test page
Cant install to Vista pc Ricoh CL3500N
Try downloding the RCPS driver.
-Carl, please let me know if this helps.
Sharing printer on a network. xp computers work vist does not.
what printer is it?
if it is the dymo, then you can send a test page. you have to test the Dymo with the shipping label that is installed in the application.
P.S. I just finished installing one.
2answers
Cant install lexmark x2600 on windows vista
You need to install the Vista version. Goto this site-download the driver-install-enjoy!! http://search.lexmark.com/printer/US/en/12L1685.html
Sharp 1642CS shared printer
You can go into your print driver and change the Driver. I dont think there is a difference between Home or Prem drivers. There is how ever a difference between 32 bit and 64 bit Vista?
When you set up the printer and share it from a PC, The printer attached to that PC can Control the Configurartion of the printer. PC's can either pull the driver from the sharing PC or you can select your own.
I would first check that the correct drivers are installed, (64bit or 32bit)
I would check the computer that is trying to print. replace the driver with the correct one.
You can open the print server -open the printers and fax folder, right click in a white area in that folder, a menu should pop up. Select Print Server from there you will see tabs, try to replace the driver from there.
Or Open the Printer Properties and there you will see Driver-Update in there.
This is a link to an explanation
Thou it was made for XP but the basic Infomation is the same.
-->Print a test page from The Printer Properties), if it works the Computer is fine, if you try to print from a program and it prints with errors. it is in the program..
http://www.fixya.com/support/r1173318-print_driver_location_pc_print_test_page
3answers
I am trying to share a printer.
Are they both under the same network? Can the pc find the laptop under network connections and vice versa? If not, then right-click my computer, go to properties, go to the tab 'Computer Name' click on the button change, and make it part of a workgroup of your choice of name. Do this for both making them part of the SAME workgroup.
Then, make your printer shared under that workgroup.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
