Question about Magellan Roadmate 1200 Car GPS Receiver
When I turn on my Roadmate 1200 says there is a Fatal Error and immediately turns off.
Posted by adt2 on
Azrael SRL
  • 11,800 Answers
Only one thing would cause that: a severely corrupted firmware. Unfortunately to reload the firmware when the unit is dead it must be dismantled and the firmware storing chip accessed directly with a special tool that only the factory has. Sending it to the factory to be repaired will cost a lot so ask a quote before doing it, you might find out that it will be cheaper just to buy a new unit.
Posted on Dec 21, 2010
Magellan roadmate 1440 fatal error
Same has happened to my gps unit too. The best bet thing is to contact Magellan and they will advise you to send the unit in for replacement with a refurbished one. or get a new one. I am still waiting for mine and as of date, nothing yet. How is it that their updates caused the fatal error? Anyone??
Jun 23, 2014 | Magellan RoadMate 1440 Car GPS Receiver
Fatal Faliure mgnshell.exe Exception:0xc0000005 Addres: 8c0643e8 Magellan Roadmate 1424 This shows up when I turn it on
THERE IS NO SIM CARD IN MY GPS
Feb 12, 2011 | Magellan RoadMate 1424 GPS Receiver
Update for Magellan RoadMate 1200
when driving after approx. 1 hour. I get an error message that says my SD card has been removed. Any suggestions?
Jan 20, 2010 | Magellan Roadmate 1200 Car GPS Receiver
My magellan roadmate 1200 will not turn on
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..
if you tried charging it with both house charger and car charger and tried to start it like i explain and it still will not start, its most likely a bad power port which is very common with this model and many other magellan models.
Sep 10, 2009 | Magellan RoadMate 1200 GPS Receiver
I pluged in my Magellan Roadmate 1200 in to the computer with the usb cable thinking it would charge. It now says it has a fatal error and that screen won't go away. Did I erase the memory on it? I...
im sure its not trash, but i dont think the usb will charge this model ( the usb wont charge all models of magellan, only some) while the unit is on, use a paperclip and insert it in the small hole on the side of the gps, that should return it to its normal state.
if you need further help, just let me know.
bill
Sep 03, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Inspiron 1200 "Fatal Error" , cannot F8 into safe mode
Press "F8" while booting up. It should give you an option to go to safe mode.
Jun 29, 2009 | Dell Inspiron 1200 14.1 XGA LCD...
Magellan Roadmate 1200 Car GPS Receiver Logo
137 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
