Question about Toys
Did you check the reverse switch? Be sure that it is turned ON. If your locomotive still will not run, check that there are no fibers wrapped around the wheel axles or any exposed gears. If none of these fix the problem you will need to take your locomotive and tender to a Lionel Service Station.
Posted on Sep 02, 2017
SOURCE: New Bright Holiday Express Animated Train - figures do not move
Make sure you the wheels on the cars are actually rolling and not sliding (being drug down the track) Most of the animation is down mechanically as the set moves.
Posted on Dec 16, 2009
SOURCE: Holiday Express Train Set
We struggled with this just today...finally figured out that you have to twist the small piece right behind the bell on the top of the locomotive.
Posted on Dec 19, 2009
Testimonial: "Thank you! Now... how do you keep it on the track? :O)"
SOURCE: My New Bright Holiday Express train set is 10
Make sure your track is clean. take a green scrub pad and rub the track to clean off any tarnish
Posted on Dec 28, 2009
SOURCE: We have a Holiday Tradition Express Set 7-11102.
Clean the metal wheel with rubbing alcohol applied on a Q Tip and clean the track with steel wool. Then try it. Cleaning it will provide a better contact for the film on it prebvents contact to run from stowage
Posted on Dec 23, 2010
I rewired my train this weekend..it now works on my outdoor setup....I found that the circuit board inside the engine had a blown capacitor and the power transitor was fried. I by passed the engine board found that it only would run backwards....went into the tender and taped into the power from tack bypassing the rectifer... By the way the engine does not start up when one uses the remote...there is a 20 second delay before starting
Posted on Nov 29, 2011
