Sony Playstation 3 (PS3) Console Logo
Posted on Dec 21, 2010
I was playing a game when my ps3 randomly shut off. If I try to turn it on, the light goes from red to blue to green and then blinking red. The same thing happens even if i turn the power switch off/on. I also cannot eject the game. Thanks Mike
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
274
Points
9
Damn u got the yellow death :s no more ps3 for u young man :(
My ps3 wont play or go to the main menu..the light will come on then it will go to a white light..after that it goes to a red blinking light..
probably it need to be fixed try to sent to the place you bout it ir call sony customer service they will help better..try not to turn it on it might get worse \.you can replace if you still have waranty on it.
Turn ps3 on light goes green then flashes blue then back to red
PS3 turn on goes green then flashing red is not a new issue. Please read this post and you can find the solution :
PS3 Red Light Blinking Fix
When i turn on the ps3 the light blinks blue and green then the ps3 instantly shut off and then the game light blinks red constantly
Yes this is the red light or YLOD you need to stop the heat build up in order to play your games, use a good guide or send it in and get it fixed.
2answers
3helpful
2answers
60gb ps3 wont start up.
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
3helpful
3answers
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
2answers
Red light green light yellowlight red blinking light
From what I understand its a problem with the backwards compatibililty(the engine/drive that lets you play ps1/ps2 games)on the 60g.Sony says they have never heard of this problem yet these models are no longer in production.I have had mine for 2 years and it died today,same problem.
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
