This is a common problem and presents a danger of electric shock. Do not use the machine. If it is under warranty, call the store where you purchased it and find out where to send it for replacement. If it is not under warranty, your only solution is a new machine. You may want to consider changing brands.
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
