Hi Marthawinter, I support the advice given by the first installer, please remove you telephone number.
You appear to have tried most of everything, if your printer has excess to use a USB to printer cable, I suggest this is your best way to proceed. Once you have achieved connection via this medium, you can then avail of a wireless selection.
If not, find the wireless set up on your printer and press the WPS button on the printer this should allow connection.
Regards
Ada
Hello, Marthawinter -
When my husband says he cannot print anything from his computer to our shared WiFi printer, the first thing I always check for him is whether his computer is connected to the Internet.
We have both our computers set to connect to the Internet (via WiFi) manually. That means our shared printer, when it is powered up, is also connected via WiFi.
If you have a similar situation, make sure your computer is connected to the Internet as well as your printer being turned on before running a test print.
Best wishes.
SOURCE: Dell AIO A940 printer and Vista.
Dell AIO A940 printer and Vista Problems
my solution is to downgrade from Vista to XP.
SOURCE: when I hit 'file' then 'print' nothing happens
Go to your device manager and make sure that you have a driver for the printer. Or uninstall the printer then reinstall it. sounds like the printer driver has been deleted
SOURCE: Dell AIO 926 driver is not installed, even though I installed it!
Hi, The problem here is that the CD has an older version of
the driver which has some known issues. Few steps will be required to fix this.
XP Driver
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=195205
XP Printer Application
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=205258
Vista Driver
Vista Printer Application
Hope this works... Please rate your feedback!!! Thanks
SOURCE: Dell A940 won't print black. New cartridge,
printer won't print black with new cartridges installed
Hello, Marthawinter - A kind tip: You may wish to Edit your question and remove your telephone number from it, unless you want to receive phone calls (spam, scam) from people you do not know. Those who volunteer to answer questions through Fixya.com probably will not call you.
