Roper FEP320 Electric Kitchen Range Logo
Posted on Dec 20, 2010
Roper model FES310BW. How do you use the self cleaning oven? Please describe the process and settings. Thank you.
1 Related Answer
Anonymous
  • Posted on Apr 18, 2009
SOURCE: ROPER ELECTRIC RANGE SELF CLEANING
how long to leave on to self clean
1helpful
I have an older Roper by Whirlpool self cleaning oven. It does not have a door lock or timer. Do I just close the door and turn the oven to clean and it will indicate when the cycle is done?
Never ever use the features of a Self Cleaning Oven. We see the damage they do here on Fixya, and the worst is the door not unlocking, and the most expensive is when they fry the mainboard.
They all have a door interlock. If you were to open it when it was running, it would frizz your eyebrows!
Why You should Never Run A Self Clean Oven Cycle & ...
General Appliance Service https://www.generalappliancesvc.com > why-you-shou...
Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or ...
Self-cleaning oven
Wikipedia https://en.wikipedia.org > wiki > Self-cleaning_oven
A self-cleaning or pyrolytic oven is an oven which uses high temperature (approximately 932 °F (500 °C)) to burn off leftovers from baking, without the use ...
‎Pyrolytic process · ‎Alternative technologies · ‎Catalytic cleaning
Self-Cleaning Oven: 6 Reasons to Stop Using Feature ...
FIX Appliances CA https://fixappliances.ca > 4-reasons-stop-using-self-cle...
A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters at an extremely high temperature (932 F° or 500 C°) to aid in ...
‎How Self-Cleaning Ovens Work · ‎Major Parts Damage
I have no manual. When i hit clean nothing happens. Help. A little hesitant because of gas
This is the manual for a Whirlpool oven, Page 14 has the self clean instructions. Your unit may have a manual latch that initially locks the oven door close and as the clean process starts a second lock is activated preventing the door from being opened.
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208522776.pdf
The second link is an article that describes pros and cons of using the self clean cycle. My experience has been on three occasions that repairs have been necessary after the self clean process so I do not recommend using it.
Why You Should Almost Never Use Your Oven Self Cleaning Function
For more information we needed the specific model and manufacture.
How o clean my roper self cleaning oven
i wouldn't use the self clean,more problems than good,the oven gets up to 1000 degrees and can damage electronics in oven,you need the model number off of the oven,you can google it and find manual to tell you how to put it into self clean but like i say you're better off doing it with easyoff,also don't use self clean near holidays or any other speacial occaisions,in case it does do damage,you might not be able to get parts or parts will have to be ordered and might take longer than 7 to 10 days depending on brand name and age.good luck
Oct 19, 2014 • Ovens
2helpful
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 • Ovens
I have a kenmore microhood 63684 turned lites on and can't get them to off,when fan button is pushed fan does not start but when lite button is pushed after fan is energized fan starts real slow and...
What this simply mean is that there has been a problem from the fan either from the wire connection or from the Cole of the fan connected to the fan motor.
There are two ways of over coming this type of problem below are the recommendation to solve the problem
First of all set the oven on self cleaning from the below instruction or make use of your owner manual to operate the elf cleaning
Please after the self cleaning you most allow the oven to cool down to it best before opening
Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
  1. Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
  2. Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
  3. Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
  4. Lock your oven door manually if your model does not lock it automatically when you clean.
  5. Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
  6. Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
  7. Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
SOLUTION 2 IF THE ABOVE RECOMMENDATION DID NOT SOLVE THE PROBLEM
Then you will have to replace the hole of the fan from the oven i.e the fan is need to be service
Hope this help?
Thank you and thank for using fixya.
1helpful
Have Roper LP Range model S8757. This is a self cleaning oven but takes forever. So I cleaned it myself and now oven won't light. Get F3 on display.
Your oven temperature sensor is bad and must be replaced.
It is inside the oven, a short metal piece extends into the oven. It is secured by a screw into the back wall of the oven.
I have a self-cleaning wall oven model w2750 . When I put the process for cleaning to operate the Clean light does not go on .... what could be wrong????
do not know how to clean wall unit i have a jenn air the # arejjw9530aas. the serial are 10208841wv . please help this is a rental house and i would like to give it back clean . thank you .
Self-cleaning oven doesn't work on Kenmore electric oven
I suspect the timer is involved in this process. It can be set to clean automatically. You need to set the complete time at least 2 hours after start.
Roper Self cleaning Oven
how dirty is the oven? if it is not bad then 2 hours if it is then 3 hours.
make sure you don't have any pet birds in the house cause it could be toxic to them.
Top Roper Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
