Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
Ive had my amp for 4 yrs pushing a single p3. Now when I turn the volume up the protect light comes on then off. The amp still has power but stops pushing the speaker. Is my amp about dead or what?
Anonymous
    New Friend:
    Problem Solver:
  • 3 Answers
Either one or both of your channels maybe going bad. It sounds like your amp is about dead BUT there is hope. If you have had it just on one channel then that channel maybe burnt up and if you have had it bridged then your channels are about gone. It all depends on what fuses you have had in the amp. And from the age and use its not going to last much longer with constant use.
Posted on Dec 23, 2010
Testimonial: "thanx alot. i fugured the same thing. happy holidays"
1helpful
I have a power acoustik ibm12000d amp had it installed to weeks ago wired at one ohm to a 15inch acoustik p3 sub worked good for to weeks hit good and everything but now its cutting off when turned up I...
Sounds like an over current condition. Your sub may be the problem. Does it go into protect mode when it cuts out? remove the sub and turn up the volume and see if it cuts out when you keep increasing the volume. If not, then it may be that the sub shorts out when turned up too much, kicking the amp into protect mode. If it still cuts out, then it may be the amp. Try another sub if you have one or borrow one from a friend.
2answers
The red protect light is coming on
It is possible that your amp is going over the threshold limit of draining current to give out the protect signal. What could be done is to first checkout if your speakers are loading the amplifier, check the rating of the speakers and the impedance, must not be too low.below 2 ohms. Now check the source signal if this is bringing in any transcient signals to power out the outputs particularily high/low freq. So decrease off your bass and treble to mid position and test again. see if there is any improvement, if so there could be a filter problem with your set. Connect an external source and see if the amp powers better , in such case check for fault in cables, input lines and ground with in the set. Repeat this and check. Hope this helps you out. Good day
2answers
THE PROTECTION LIGHT COMES ON
make sure your ground is drilled threw thick metal and the paint is scraped off and make sure that all the wires connecting the amp are 4 gauge or higher and if that doesn't do the trick get a better amp that can throw more power
1helpful
1999 gmc sonoma, auto, push button 4wd. jacked the rear wheels off the ground and pushed 4wd button, front drive shaft turns, but no power to front wheels, seems like everything is working like it should,...
Ive gone thru this THREE TIMES w/ my '99! Theres a thin, rubber vacuum hose that wears thin, gets dirt/oil/water in it & shorts a relay. The last mechanic replaced the hose w/ steel brakeline & Ive had no problems for 2 yrs.
Connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
2helpful
3answers
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
Protection light is on
un plug rca
and disconnect all spk from amp and turn on if light dont come start with one rca at a time and one spk and connect and you will find the problem
Yamaha p4500 protect lights do not go off at power up
You only normally get that when the Volume over peaks, and the amp will automatically cut out to prevent it fron blowing the whole P.A up.
If you know it was working fine before the wires were twisted together, then best try undoing what was done, and making sure that the Amp's Volume is turned down to minimum.
Protection light coming on and amp cutting off
yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Top Rockford Fosgate Car Audio & Video Experts
Marvin
Marvin
Steve Sweetleaf
Steve Sweetleaf
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
