E1 code on kenmore front load dryer
Hello there
I have written a list of codes that should cover your problem nd give you some idea what to check ok
E1 or E2
Thermistor
Failure
The dryer
will not operate if the exhaust temperature drops below
18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error
code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the
error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
E3
Touchpad or
Software mismatch
Flashes when
there is a touchpad or software
