Question about Motorola Mag One BPR40 Two Way Radio
How do you reset the password on a Motorola BPR40
Posted by wa3bxw on
Motorola BPR 40 will transmit,but not receive through the microphone. Works fine as a handheld
You may have one of three problems: Your audio accessory jack is bad, you are using the wrong mic for the radio, or your mic is bad. Try the mic on a known good BPR40 and if it test good, if so, your BPR40 with the problem needs a new audio accessory jack. (Repair is available for this model.) We have found the BPR40 will only work properly with the remote speaker mic designed for it, despite some other Motorola mics appearing to fit the jack. Construction grade mic PMMN4013 is a good option, as is the lightweight PMMN4077.
Jul 08, 2015 | Motorola Radio Communications
Mag One BPR40 not powering
Contact Motorola Solutions (http://www.motorolasolutions/support)
Jun 26, 2014 | Motorola Mag One BPR40 Two Way Radio
How do you synch a set of Motorola MagOne BPR40 radios to a new set of the same radios?
BPR40 radios are dealer programmable using Motorola proprietary software and cable.
Jun 23, 2014 | Motorola Mag One BPR40 Two Way Radio
How do i remove the circuit board in the BPR40
PeteD.
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Mar 13, 2014 | Motorola Headset Mic Vl130 Pr400 Bpr40...
Have two bpr40 need to find out the frequencys
The BPR40 is a dealer programmable radio. The frequencies would need to be read out using Motorola proprietary software. The only thing you can tell from looking at the radio is whether it is VHF or UHF. Model number AAH84K... is VHF and AAH84R... is UHF.
Best regards.
Aug 20, 2013 | Motorola Mag One BPR40 Two Way Radio
I bought 2 Motorola bpr40 Mag One radios, but one is used and their channels do not match. How do I return them to factory defaults?
The BPR40 is only programmable by Motorola proprietary software. The easiest method for programming them to match one another would be to take them to a dealer. Prices vary, so you might want to call around and price check your area dealers.
Best regards.
Feb 09, 2013 | Radio Communications
How do I connect Mag One BPR40 two way radio by Motorola to CP100 two way radio by Motorola? I already had about 8 CP100's and we just got 2 new Mag One's. Thanks.
The Mag One BPR40 is dealer programmable. You have two choices:
1) Reprogram your CP100s to match the new BPR40s. For this you would need to know what the dealer programmed the BPR40s to... OR
2) Take your BPR40s back to the place of purchase and request they reprogram them to match your CP100s. This should be a free service since you just purchased the BPR40s. They will need to know some settings from the CP100s to make the match.
Best regards.
Sep 17, 2011 | Motorola Mag One BPR40 Two Way Radio
How do you open up a bpr40 to get to a broken circuit board in radio ? It is my personal radio that Motorola service center said was unrepairable so what the heck ? Thank You !
You can use two small screw drivers, one on each side of the bottom of radio. Insert and lift up. Knobs have to be removed. They pull off.[can be difficult] Use a chassis removal tool[6685666D01] that can be ordered from motorola. If the repair shop sent it back unrepairable,you can try sending to motorola.[$134.00 flat rate repair] or just cut your losses. Would not invest any money because it is an inexpensive radio.
Aug 25, 2011 | Motorola Mag One BPR40 Two Way Radio
Are my Motorola MagOne BPR40 handheld radios narrowband capable?
Yes. They are programmable to either wideband or narrowband on a per channel basis.
Best regards.
Feb 16, 2011 | Motorola Mag One BPR40 Two Way Radio
Motorola Mag One BPR40 Two Way Radio Logo
208 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
