Hello
Your typing in192.168.1.1 correct? OR 192.168.1.0
The username is admin
The password is password
Then hit the enter key.
Connect a Ethernet cable from your router to the computer and then try.
Ip address:192.168.1.1
Username:admin
password:admin (flip the router over and see for the username and the password)
To open the set up page of the router of the
router , one of your computer should be able to go online through the
router.
It could be a wired computer or wireless
computer.
If it is a wireless
computer then make sure that the computer is connected to your own
wireless network.
Do not change any wireless
settings on the router using a wireless computer.
OK
! Now you have a computer online through the router and you want to
open the set up page of the router.
First step is check the IP
address of the computer.
Check the IP address and the Default gateway on the computer.
For Windows XP
START ==> RUN ==> type in cmd
in the RUN box==>
click OK or Hit ENTER . You will see a black window that is a command prompt .
In the black window type in " ipconfig " ==> and Hit ENTER on your key
board .
For Windows Vista and Windows 7
click
on START ==> type in cmd in the start
search
box ==> enter ==> you will see the black window. Type in " ipconfig "you will see a lot of
information. Try to find out the local area
connection IPv4 address .
Note
down the Default gateway number.
For MAC OS
Click APPLE
icon in the right top corner of the computer. Go to System Preferences
==> go to Network ==> you will find the option Built in Ethernet or Airport whichever is
connected. If you go to that you will find the Ip address and router
Address.
The default gateway is the IP address of your router.
This IP address of the router will be used to open the set up
page of the router
Now you got the IP address
of the router.Open the Internet Browser ( Internet Explorer, Firefox,
Safari )
In the Address bar of the browser Type the IP address of the
router.
Do not type http:// or www
just type in the IP address only.
It will
ask you for the user name and the password of the router.
This is the User name and
the password of the router and NOT
the wireless password. On a wireless router, there are 2 passwords. One
is to access the router and the other one is for the wireless network.
For most of the routers the default password
will be " admin " . for some routers the default password is " password
". For Linksys router the default password is admin and no user name.
