To reset the drum light on your Sharp AL2020 copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the "auto" key (exposure mode) then the "C" key then the "auto" key again.
So in other words C, Auto, C, Auto
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
Good Luck and Thank You for using Fixya.
WheatlandServices
Very sorry, I posted the wrong reset procedure. Use the same procudure as I listed above but instead of entering 24, enter 14. That is all you need to do as the machine will rest automatically. Again sorry for misreading the post. If this works, please update my helpfulness rating.
Thanks Edwin Martens, it worked for me....
YEAH!!! I USED IT NOW IT WORKS THANK YOU FOR SUPPORTING
Awesome. Thanks for taking the time to write a solution, worked a treat.
This worked perfectly, thanks a lot
