You need to install on your computer ActiveSync/Windows Mobile Device Center. To install this, insert the "Getting Started" CD into your computer and follow the setup steps. If you don't have the CD anymore, you can download the ActiveSync from this link.
Once ActiveSync/Windows Mobile Device Center is installed you connect the HTC Snap to your PC using the USB cable supplied with your HTC Snap, then you will be presented a configuration Wizard that will take you through the set up process.
You can connect the device to your computer using USB either as an External Drive or through Microsoft ActiveSync. If using Windows Vista, you will use Windows Mobile Device Center (WMDC) rather than ActiveSync. Simply plug the device in and choose an option on the screen of the device.
If you will use it as an External Device, you can copy data on it as you would copy on a USB flash drive, with copy and paste.
Another option is to use the bluetooth to transfer files, if you have a notebook which has bluetooth capabilities or you have a dongle.
