Have you read the instructions.
Have you disconnected usb while installing disc,this is important.Wait till the installation tells you to plug in the usb adapter,then the driver will detect the adapter at the port because it is now searching for it.Good Luck.
ENABLE WZC
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage. 2. Go to Services then go to Service and Applications. 3. Double click on Wireless Zero Configuration. 4. Change the Start Up Type to Automatic and click on Apply. 5. Click on Start and press OK to close the window. 6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'. 7. Right-click on the wireless Network Connection icon and select 'Properties'. 8. Go to the 'Wireless Networks' tab. 9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'. 2. Right-click on the wireless Network Connection icon and select 'Properties'. 3. Click on the 'wireless network' tab. 4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK. 5. Right-click on the wireless Network Connection icon and select 'View Available Networks'. 6. Look for the SSID (aka Network Name) of the Wireless router or access point. 4. Highlight the SSID from the list that you want to connect to. 5. Type the security Key here and click on the 'Connect' button. 6. You should have successfully established a wireless network connection.
Have you received the latest flash for the board. Could need the bios update so go to the website asus.com and find your board and flash it with the latest update.
