Question about Sceptre X7GNAGAV 17" LCD Monitor
Was intermittnet at first, now nothing. Power light just blinks green while you have the VGA cable plugged in and you can't turn it off with the VGA cable connected to an operating computer. Unplug the VGA cable and the power light blinks green and amber and you can turned it on and off. I tried a different VGA cable - no help. Have not opened it up and looked at anything yet. The last thing I saw on the screen was a message saying "No video signal".
Posted by n1nxu_extra on
  • n1nxu_extra Dec 23, 2010
    budmrtn you were right on the mark. That fixed it. Thanks.
Bud Martin
  • 11,361 Answers
Look for bad caps, if you see any bad one you should replace them in a set.
Bad cap can look normal.
See pictures here:
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 20, 2010
  • Bud Martin
    Bud Martin Dec 23, 2010
    Thanks for the feedback, please leave good testimonial, thanks!
I've got a Scanport H21 monitor that the green light comes on but has a black screen. Can not dring up a menu or "VGA IN" message.
You can try a different cable for VGA. Check if the port is lose. The green light is only indicating a proper power supply to the monitor. The display is very much dependent on the VGA cable. If your monitor also has HDMI port, you can try to connect using that cable (provided the display adaptor also has HDMI port). If nothing works for you, take it to a hardware engineer or local repair shop.
Jan 20, 2014 | Scanport H21 21" LCD Display Monitor
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
Red light on computer monitor, black screen, but nothing else
if the power indicator light from green then turn to red with no display, check the power supply board which may have leak or bulged capacitors. check also weather your vga cable is good, if no signal the monitor will turn to off.
Oct 14, 2012 | Computers & Internet
My HP Monitor Model No: L1706 problem
I sure sounds like you have backlight problem, since when the VGA cable is connected the power LED turns GREEN and blinks when VGA cable is disconnected, it means the video signal is getting to the monitor OK, so more likely the problem will be in the monitor, but just to be sure, you should also try this monitor with another PC first.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 01, 2010 | HP L1706 17" LCD Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
I can't get my tv to turn on... nothing but blinking red light
Dont know if this will work for you or not, but my brother gave me his because of the same problem. It would power up and a green light would come on, then after 10 -15 seconds it would change to a red blinking light. I plugged a usb cable into the service port on the side and left the other end unplugged. Then plugged the tv back into the power. i took a small screwdriver and ran across the contacts in the end of the usb cable until both the red light and the green lights came on. I did this several times listening fot the clicking noises in the TV. after doing this for approx 20 seconds, i pressed the power button and the TV worked fine. 5 days now and no problems. Only thing I can think is I somehow reset the software and now it is working fine. Hope some of you can figure this out and give it a try. if the TV is just sitting, you have nothing to lose
Aug 17, 2008 | Philips 26MF231D 26 in. LCD Television
NEC MultiSync FE2111SB 22in monitor problem
a blinking green light usually indicates no video signal. check your cables, and if you have another computer, try it on that. otherwise, carefully check your vga signal cable, and the connections on the neck board [where the crt plugs into]
Aug 11, 2008 | NEC MultiSync FE2111SB 22" CRT Monitor
SBlinking green light
Have you tried disconnecting the power from the wall? Or power cycling your entire entertainment center? Possibly even check to make sure the VGA cable (or any other cable) didn't somehow come looose?
Jan 21, 2008 | Insignia LCDTV26 26 in. Television
Sceptre X7GNAGAV 17" LCD Monitor Logo
237 people viewed this question
Top Sceptre Computers & Internet Experts
Ekse
Dave Burton
Level 1 Expert
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
