EliteGroup K7VTA3 V6.0 (K7VTA3_V6.0) Motherboard Logo
Posted on Dec 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the LAN driver for my k7vta3 v.6.0 - EliteGroup K7VTA3 V6.0 (K7VTA3_V6.0) Motherboard
Anonymous
Level 2:
  • Expert 298 Answers
  • Posted on Dec 20, 2010
Anonymous
Expert
Level 2:
Answers
298
Questions
Helped
122892
Points
871
Drivers for your LAN, click link below:
http://download.ecsusa.com/dlfileecs/driver/mb/lan/via/VIA823x_40.zip
kindly rate if it helps,
levibit
Msi lan drivres
Hi
The term "LAN Driver" is meaningless without associating it with an Operating System and a specific item of Hardware.
There is no such thing as a "LAN Driver".
There are only XP LAN Drivers, Vista LAN Drivers or Windows 7 LAN Drivers, Mac OSX Tiger LAN Drivers. Mac OSX Leopard LAN Drivers, Mac OSX Lion LAN Drivers, Linux Red Hat LAN Drivers, Linux Ubuntu LAN Drivers, etc
Although drivers seem to mainly be about hardware, they are actually mainly about software. The Driver does not physically control the Motherboard's Devices. The BIOS and the Operating System do. What the Driver does is (just like a human interpreter for a guest who speaks a different language from his host), introduce the Device to the Operating System and help them to communicate with one another, with the Driver taking instructions from both and passing it back and forth between them.
So when one mentions Drivers, one must also mention the Operating System it will be talking to. In order for that to be possible, the 2 must share a common language. If they do not, then the role of 'interpreter' is impossible, because, then neither the Driver nor the Device will be able to understand what the Operating System is saying.
Identify the Hardware and the Operating system and then you can find the drivers if drivers exist for the particular hardware and the Operating System in question.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa
I need lan drivers to download
Before downloading lan driver you need to know the exact model and brand of your lan card.... after you knew that all you need to do is to google it... for example: "model of your lan card" driver download
search it in google....
akuma_ryu21 rate it please tnx!!
Lan driver
You need togo to gigabytes web site. Click on support and then select your motherboard. What you need are the motherboard inf files or driver and the lan driver.
http://www.giga-byte.com/
click on support and downloads then put your motherboard in the search box GA-8I845GVM and you should see one result listed under the 775 socket types. Click on the download tab and then select your operating system.
You probably should get all of the driver but the two you need are the intel inf under chip set and the realtek under lan. Run the INF first then reboot if required and run the lan driver. After that you should be able to setup your lan and get on the net..
Usually it is the audio that won't work and the lan runs fine on the default drivers. Also the default video driver may no have all he control option as the one from the download page.
1helpful
2answers
I m unable to find lan drivers. i've a lan card
You use built in Lan Card or Lan Card which is in PCI slot.
1st you know the name of the Lan Card. But You can download different type Lan Card Drivers. Lan Card Drivers
4helpful
My dell lan card is not working,i cannot connect to internet.
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
1helpful
3answers
Ethernet not work
Check in the Device manager to see if all the devices are enable and working.
The one with a yellow ? against that device requires a driver installation.
Is the LAN device OK?
How do you intend to setup your LAN, is it for Internet access or a home network?
I need more information on your problem, together with error messages.
About lan driver
reinstall the driver for the nic that came with the laptop and it should work. If you don't have the driver you will need to download it from the manufacturer or a driver download site like drivers.com.
Traxcat
4helpful
3answers
Lan Driver
i have lan driver problem, i need to lan driver for intel d865gbf motherboard
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
