Question about Neovo F-417 17" LCD Monitor
Hello! I need the list of components used in my ag neovo f-417 screen, one of the integrated circuit is toasted so i cannot read on it anymore to find the correct component name to replace it! Thanks a lot!
Posted by blackizzy on
  • blackizzy Jan 04, 2011
    no it is the component # U-801
Anonymous
    New Friend:
Is this one of the 4 transistors on the back of the inverter board
2 x STU9916L
2 x STU2040PL
Posted on Jan 01, 2011
2answers
Driver for neovo F417 lcd screen windows 7
No drivers are necessary. If Monitor is seen as "Plug and Play monitor" is ok.
I boot and my screen is hit and miss, so screens i see most i do not. worked intermitent, so times it would work, then it just stopped all together. i replaced the monitor and it works just fine. i then...
Which version of the monitor do you have? Built-in power supply or external AC adapter?
http://www.agneovo.com/us/content/f-417.asp
or AC adapter: http://www.usadapter.com/LCD-AC-Adapters/AG-Neovo-F-417-LCD-Adapter-12V-4A.html
If it uses externa; AC adapter, then you need to attach a car bulb such as 1157 using high filament to the adapter output and see if it still putting out 12vdc with load.
If it uses built-in power then you need to check the power supply section first.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Please ? i need shematic diagram for monitor NEOVO F - 417
jais un probleme avec mon monitor lcd nuevo s17 ,il s'allume et l'écran ne s'affiche pas c'est quoi la solution a se probléme
2helpful
AG Neovo Monitor not working
nothing you can reset from monitor other than color brightness. You can contact with AG Neovo as [email protected] to have a RMA number and they will estimate you the repair fee if it is out of warranty.
Occasional Distortion
For some time we used to sell these monitors in our store. Some of these same models do have a defect which can cause some of the problems you all are having. Neovo does come with a good warranty, at leasted they did when we sold them at the store lasting at least 3 years. We had a monitor that had random blue stripes which Neovo replaced. One thing you may want to try before throwing in the towel on your monitors is reloading the device drivers on the montor. These monitors came with a CD. If you cannot find it you can get the drivers from here http://driverscollection.com/?H=F-419&By=AG%20Neovo . If you think you are still under warranty, give Neovo a call they will may just replace your monitor with a new one. Good luck....
7helpful
6answers
Screen goes black in half a second....
Call the service dept. in the above post. Tell them the model and serial number of your monitor and order a backlight inverter board(approx. $35 plus shipping). Open up the monitor and plug it in, should fix the problem. This problem could also be caused by one or more backlights(small flourescent tubes) being bad. I just fixed a Neovo F-417 display by replacing one of the backlight assemblys. I also just fixed a Neovo E-17DA monitor by replacing the inverter board.
Neovo F-417 17" LCD Monitor Logo
Top Neovo Computers & Internet Experts
Tom Chichester
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
