Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
SOURCE: router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Feb 01, 2008
SOURCE: cisco 1721 router serial port not showing any loop.
the problem is with your modem....did you tested the local loop from router to modem....are u getting local loop from one modem till router or not...try first checking local loop from modem to router...
Posted on Feb 11, 2009
SOURCE: How to connect Wireless router to Cabel Modem and Vonage Modem?
First of all: it would be good to know which devices you are using. This would help to be more specific.
But anyways:
If you have any more questions or this desciption is not clear to you,just come back here and leave a comment - I'm happy to help.
Posted on May 23, 2009
SOURCE: Can't get 2 laptops and desktop to connect all get internet...
Posted on Aug 12, 2009
SOURCE: I have a cisco linksys wrt54g2 v1 that I have
Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
Posted on Oct 24, 2009
Testimonial: "Thanks a bunch!! I was about to pull my hair out! You are the Man!!"
Nov 22, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Aug 29, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Jun 21, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Nov 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Jul 21, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Jun 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
May 18, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Feb 27, 2011 | Cisco Linksys Wirelessn Router Black...
Dec 25, 2010 | Linksys E1000 IEEE 80211bgn Wireless...
Nov 27, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Jul 20, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Aug 02, 2017 | Cisco Linksys E1000 WirelessN Broadband...
513 people viewed this question
