If you are having trouble accessing itunes and app store then it is possible that you have not updated your itunes to the latest version. Open itunes on your computer and check for updates then everything should start working again.
Re-install the iTunes. Go to Start/Control Panel/Uninstall a program/Select iTunes/Click on Uninstall Restart your computer Go to Apple.com and click on iTunes Download and install them.
I would also recommend you to buy a special device which helps to prevent your computer from turning off when there are power schortages.
Are you able to access your itunes account from another pc or device? If so then I would uninstall itunes and reinstall. A file may have become corrupted which has caused the issue. Restarting your computer may also resolve the issue.
. Go to Sharepod Folder. Double click on Sharepod.exe. If message “Failure to
initialize†appear on your screen, you need to download the Microsoft.NET
Framework 2.0 to run sharepod. Note this program is installed by default under
vista.
Please be careful not to run Sharepod and iTunes simultaneously as iPod might get
out of sync with both software.
Disable iTunes
Ensure Ipod is connected to your computer. Select removable disk in My Computer,
Open iTunes if not set as default. Select iPod and click Settings and disable option Open iTunes when Ipod is attached.
close down itunes and then you should be able to download the latest version of itunes from the apple website and then run the installer. If it does not work due to itunes in your applications folder put this version in the trash and then run the installer again. Hope this helps
once u plug in ipod via USB just let it sit and open itunes, u should put ur songs in itunes before connecting ipod, auntomatically it should start importing songs from itunes to ipod and should show u on top of itunes
good luck
- if any trouble talk to apple or any electrogeek
