JVC AV-32260 32" TV Logo
Posted on Nov 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
JVC Big Screen TV
Please HELP my TV just went dead, were or how can repair it?
what wil the cost be
I do believe it is not good to move it on a bakkie
Thanks, God Bless
Ben Loubser
072 577 1196
(011) 816 - 2342
15 Tavertyn ave
Dersley Park
Springs
Larry
Level 3:
  • JVC Master 5,042 Answers
  • Posted on Nov 28, 2017
Larry
JVC Master
Level 3:
Answers
5042
Questions
Helped
1240311
Points
18413
If its totally dead, then its either the main board or power supply
5 Related Answers
Anonymous
  • 45 Answers
  • Posted on May 20, 2007
SOURCE: jvc rx-805v repair
repairing amplifier is not easy as you think, one mistake could lead to more damage, simply replacing output transistor may not solved it, and may damage the new parts, very risky. If you are not knowledgeable on this task, don't do it. Amplifiers are the most risky gadget to repair especially the high-powered amps.
Anonymous
  • 1153 Answers
  • Posted on Sep 08, 2007
SOURCE: blue screen nonworking tuner
Yes get number of side of tuner and call around. I use www.bluestar-online.com for some cheap parts. But there are others, MCM, Tritronics, Dalbani etc.
Anonymous
  • 13 Answers
  • Posted on Sep 15, 2007
SOURCE: JVC Camcoder GR-DX77 has no Picture in Record Mode
Definitely, don't use Sony miniDV tapes! The fault occured because of rough handling of the mechanism during cassete insert or from dropping the camera.A guide arm inside the mechanism is deformed and the mechanism can be changed in whole for this.Contact a JVC authorized centre.The price for this can be half the price of a new camera. After all, it's your fault. This is a good camera if you know haw to handle/ use it!!!
Anonymous
  • 3130 Answers
  • Posted on Sep 29, 2007
SOURCE: big screen tv repair
There is a short in this TV set somewhere. The TV set is trying to come on but because of the short, the power supply shuts down. No if it is not the over current shutdown, it could also be the main power supply with an over voltage shutdown protection mode. These are solid state TV sets and should only be worked on by trained techs. Good Luck
Vista Electronics
  • 1694 Answers
  • Posted on Dec 31, 2007
SOURCE: I CAN'T GET THE CC OFF OF MY TV
Remote control original is part # RM-C1200G-1H ...best to
have JVC original......$25.00......................T.
1helpful
Hi there I have a jvc tv 'LT-42X788' when I power on the cbc sign comes on I here a click and screen shuts of there's a blue light that came on when I power on it stays on any help thanks
@Thomas Scissons
"JVC LT-42X788 display fault..."
Hi Thomas.
Please pick one:
Power supply board (possibly a blown capacitor):
A TV-tech can repair at reasonable cost, less than a new set.
The main board itself has a control / display section fault:
The screen / panel is shot:
Beyond economical repair - renew set.
Hope this helps.
Clive.
Green and Red (thin lines) across entire screen [JVC 70 G886 HD TV]. Screen went to all green (wide and thin) within 1/2 hour and picture hasn't come back. "Input selection" box is visible and clear...
Try a "hard reset" first by unplugging the set for 30 seconds. and if no help, you may have a problem with the SMPS power supply, it might have a bad capacitor or two by now. Worth repair if engine is good compared to a flat panel.
Problem with the JVC AV-36D503 36" TV.........TV will not turn on. Bought TV New in June of 2003...Dec 2003 the TV went Dead...They replaced the Safety Fuse. If same problem would you have any idea...
Tv might have more dead parts than just the safety fuse.If tv have only a power supply board fuse only they can do it for u wright there take the tv aparts and replace the tv power supply safety fuse like 15 mins job and will cost u like $40 dollars take it to any tvs repair shops.
1helpful
2answers
Turned on my RCA P46924 today and played fine for 5 min. then picture curved and turned to 3 different colors seperated on same screen. Turned TV off and now will not turn back on. Please help?
Ur tv have convergence problems,before ur convengence ICS totally went dead.U must have tools like soldering iron,solders,solder witch,and know how to solders to fix this problems ur self.Must replaced 2 convergence ICS,and some or all it resistors.Tries websites like Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Broken JCV Plasma Screen
Its prob not worth swapping lcd screen as new ones are excessive cost compared to buying a new tv. Power supplies often fail on lcd tv s so u may find a faulty one locslly being chucked with good screen but no power,to make one good one.connections vary make to make but most units are made by just a few manufacturer s so so can be interchanged,sorry its a wasteful world
1helpful
2answers
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
3helpful
3answers
HELP HELP PLEASE JVC TV
This is probably too late being a year later, but for the reference of anybody else reading this later on down the line, THe convergence IC's need to be replaced. STK392-110. There are two chips and they both should be replaced in tandem. After that a simple customer convergence is all it takes to get it back to normal.
2answers
JVC DVD player problem
You have set the DVD to progressive output for your big tv. The little one will not accept this. Your manual will tell you how to reset it. The remote may be needed. Reconnect it to the big tv and check the menus.
Blue screen nonworking tuner
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
