Cell Phones Logo
Question about Nextel i836
Need unlock code for this phone. Nextel/Sprint want provide these unless its an active phone with them.
Posted by medic1752 on
5 Related Answers
Anonymous
SOURCE: I forgot my keylock code for my Lg Fusic sprint cell phone
the code is the last four digits of your cell phone number
i had the same problem and it worked
Posted on Oct 16, 2007
Anonymous
SOURCE: Motorola i880 Nextel/GMS UNLOCK
you cannot use an i880 abroad as it does not have gsm capability, the i880 is iden only
Posted on May 17, 2008
Anonymous
SOURCE: special code
special code Motorola Boost 1835
Posted on Feb 21, 2009
Anonymous
SOURCE: sprint nextel i want to unlock ic902
1st press ok main key then press star.
Posted on Apr 16, 2009
Anonymous
SOURCE: Unlock my Sprint LG Lotus Phone if i forgot my lock password
As long as you know your security code you can retreive your lock code. On the Lotus dial ##3282# scroll down to Advanced, choose View, then scroll down to option 5 which should be the Lock Code and select it. You will need to enter your security code here which typically is 6 zeros.
Posted on Nov 11, 2009
Consumer cellular motorola subsidy code
Due to legal requirements Motorola doesn't provide Subsidy Codes, also known as "unlock" codes. This has to be provided through the carrier.
I have a Nextel sim card in my boost phone i335 I need special. Code
Call Nextel and have them activate that phone to your account.
Nextel, Sprint, and Boost are the same company.
Nextel is the iden network,
Sprint is the CDMA network
and Boost is the prepaid network. But their owned by Sprint
Sep 02, 2011 • Cell Phones
2answers
How can i unlock my blackberry 8703e
Now you can unlock CDMA only set too. So you can use nextel/sprint cdma to other cdma network in usa too.
http://blackberryunlock.mobi/
1helpful
3answers
How do i unlock my motorola i580 cell phone for nextel
you have to get the unlock code from the carrier that provides that phone. each code is specific to each device.
4helpful
2answers
Will my phone work
Above is incorrect. Boost uses two different networks each is different technology. The one using SIM cards is the IDEN network (Nextel). The other is Sprint (who owns Boost) and that does not take a SIM, it's a CDMA network. All Sprint phones can work on this network,but you must get Boost to activate the phone. They won't do this unless you are already a customer and tell them you are replacing a broken phone, then give the Sprint phone ESN# (under battery) for them to log in your account. If you have a Sprint LG Rumor it will then work without unlocking or flashing, no changes necessary.
How to active a motorola ic902 with a nextel account
Go to a 3rd party NEXTEL/Sprint store not a Sprint owned store. They do not know what they are doing with these Hybrids. You need a new 128k sim card.
Unlock codes
You may need to purchase a new sim card for it to be compatible with your nextel phones BUT it won't hurt to call customer service and try to activate that sim card under the ic902's serial number. Because your ic902 is also a sprint phone it works off of a different network and will need programming. Customer service will be able to activate your phone and give you the info needed to get your phone up and running.
30helpful
9answers
Need to unlock lg rumor
the lock code is the last 4 digits of your phone number (unless you previously changed it when you first got the phone). This is the default for all phones - again, unless you already manually changed it. If you did then you'll need to call customer service and they will reset your lock code. Pretty easy.
Sep 30, 2008 • Cell Phones
3helpful
4answers
Requesting special code
I have a Motorola i880. When placing sim card in the phone it is requesting a special code
3helpful
5answers
Top Nextel Cell Phones Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
