Hyundi lantra sports wagon 1997 has no spark in one cylinder.i have changed spark plug and checked lead is ok
Pls try to check/replace your distributor cap and/or the rotor. A friendly reminder, pls check that the spark plug gaps are within specifications, the wider the gap the the more arcing from the rotor to the bottom terminals of the distributor cap, the faster the burning/deterioration. If at all possible, try to replace with Bosch or Beck Arnley brands.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
