SOURCE: Vegetable section too cold, freezing the vegetables
if youd like you can remove the affected crisper, locate the "adjustment slidelever" and remove it, behind there youll find a hole(which is what youve been restricting to lessen the cold air flow.) try wadding up a ball of perma-gum, window sealer, some sorta plug forthe hole, its not nessecary for function of refrig, only to make the crispers colder, but usually too cold. blocking of fthe hole willl make the crispers only as cold as rest of refrig
SOURCE: I have a GE side by side GS25LGM. The fridge side
try turning down the thermostat for the freezer side some times the controls seem backward. However most fridges are desighned for thwe freezer side with some thought giving to pushing some air to the refrige side. in most cases it easier to start back at medium settingsfor two or three days.
SOURCE: vegetables are freezing inside vegetable bin
Most likely your refrigerator is set at too cold a setting. Just turn the temperature adjustment to a warmer setting.
SOURCE: My food in my vegetable bin is freezing.
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try:
SOURCE: vegetable crispers freezing my vegetables
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp.
The problem could be the electronic control if
you have one or the mechanical linkages.
