Question about Adobe Acrobat 7.0 Professional
Can not print as pdf for vista - Adobe Acrobat 7.0 Professional
Posted by varyyoung on
marclaurens
  • 100 Answers
Print as a pdf does not actually print anything as far as i am aware , it simply creates pdf document.
you should just choose print perhaps.
Posted on Dec 19, 2010
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
I have a Print ship Pro Publisher Deluxe which is not working with my Windows Vista in converting the file to pdf. The Broderbund pdf printer will not set up. It keeps telling me there's an error in...
I would try installing another pdf printer, like the free PDFCreator. That way you could just choose a different printer from your Broderbund software, and print the same file to PDF.
Give it a shot :)
Good Luck
Jun 06, 2011 | Broderbund Print Shop® 21 Pro Publisher...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Cant open dpf and print
i hope you meant pdf in that case
please download and install a pdf reader,
open the pdf file using this software and print it.
to download pdf reader click on this link
for windows xp users
download
for other operating systems like vista
download
Hope this helps you
Thank you
Sep 27, 2009 | Computers & Internet
My system is windows vista 64 bit. Print shop
you have to go to the help section or help tab at the top of your printshop window, on your printshop program...and then click technical support , and it will give you options...click on the option of troubleshooting and it will take you to the broderbund direct online troubleshooting page, and click on the appropriate option for windows vista 64bit, and it will walk you through step by step; which involves going into your printer port settings under control panel section of your computer, and just follow the online directions...I just did it and my newsletter on printshop 23 deluxe is now saving without problems!
Aug 11, 2009 | Encore The Print Shop 23 Deluxe Full...
Inabilityy to print from QUicken 2008 under Vista 64-bit OS
I can only speak for my situation, which is Windows Vista Home Premium 64 bit with a HP7590 all in one printer. I had all the problems I read about, note I was only interested in printing "reports" from QUICKEN 2008 DELUXE.
I was able to use the Quicken PDF printer, but I just installed the HP 990C printer drive and found that report printing now works. I did delete the PDF printer before I installed the 990C, but I would guess that's not necessary.
HP considers the 990C a "generic" printer.
Hope this helps.
Aug 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP LaserJet 3150; no driver found for Vista
http://www.bioticaindia.com/download.php?file=hp-laserjet-3150
Jun 25, 2009 | HP LaserJet 3150 All-In-One Printer
I have the Printmaster Platinum Version17 , I cannot save to pdf files?
As a work around untill we can figure this issue out. http://www.acrosoftware.com/Products/CutePDF/writer.asp
This is a FREE PDF Print to file program.
At the top left of the page the are links to the PDF Creator and the Required GPL Ghostscript 8. The program will not function without it. Both programs work with x64 Vista. Read the website for the other benifits or the program.
Apr 01, 2009 | Broderbund PrintMaster Platinum Version 18
Creating PDF files with Vista
Dear Andrea, its working for me. Simply Press Ctrl+P and page set up would appear, you can do it from there.
If that was helpful please press solved.
Nov 07, 2007 | Adobe Photoshop 7.0 for PC
Adobe Acrobat 7.0 Professional Logo
29 people viewed this question
Top Adobe Computers & Internet Experts
Jane
Level 1 Expert
Lee Hodgson
Lee Hodgson
Chris May
Chris May
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
