Question about Nokia N72 Cellular Phone
My nokia e72 still stay in offline mode .....how to change it..
Posted by nazfifah on
Anonymous
  • 109 Answers
Offline may mean that the Sim Card was not correctly placed or a fall or shock on the phone has requested you to switch to offline mode and thus you are on that mode. This can be cured by turning off the phone and removing and putting back the Sim Card. You can also just change the settings to General if you had earlier inadvetently chosed the offline mode.
just try this one!!! first you do is to click the power switch for 1 sec. then it appears: switch off,lock key pad,general,silent,etc. you will see a offline word in the screen.... just choose general profile.... and this words will appear "phone is currently in offline mode. change profile to access network?" just choose yes.. i hope it will help your problem....
please rate :)
Posted on Dec 19, 2010
zeabrylemyky
    New Friend:
My E72 are still in offline mode even i had tried to restore it,also,there was a selection,while i turn it on,to continue in offline mode or no,then i choose no,to activate the general profile,but it is still in offline mode,please help,give me the solution for my E72,
Posted on Apr 30, 2012
Anonymous
    New Friend:
And now its giving an error POPUP CLOCK ALREADY IN USE.
Posted on Nov 16, 2011
Anonymous
    New Friend:
Please change sim protector i.c.
Posted on Dec 23, 2010
  • Anonymous Nov 16, 2011
    my handset fall down and afterwards i had been using for an hour, then i suddenly used messaging and other applications at once, meanwhile when i was giving it multiple tasks it got struck and till yet signals are not coming Messaging application is not opening and if i have tried to change network manually it says phone is set to offline mode, now general profile has been selected but in network menu its not allowing to change it on automatic.
    what should i do? please help
2 Related Answers
Anonymous
  • 178 Answers
SOURCE: my nokia e72-1 went offline.
Hi
Just press your switching on/off button and press once there you will find an option offline and many more any one.
And another way is to ,go to profile selection or simply visit network selection and do automatically selection and restart your handset.
Thanks
Posted on Sep 06, 2011
thyake
Thyake
  • 341 Answers
SOURCE: how to remove offline mode
Please restart your phone. After restarting, it will ask do you want to continue in offline mode, select NO. This should solve your problem. Make sure you have SIM card inserted in your phone.
Posted on Feb 26, 2011
My nokia c5 is in offline mode.icannot teceived text and calls.how can i change my mode to online
Make sure your phone is not in Airplane / Flight mode. Go to Settings > Profile. Select Normal.
If your phone still stays in offline mode, it is possible there is a problem with your SIM card. Turn off your phone; remove the SIM card; reinsert the SIM card; turn on the phone.
If the problem still persists visit your mobile phone store.
4helpful
2answers
My nokia e7 stays offline mode while sim inserted
After inserting the sim card it goes restart and ask for changing the profile from offline,when i try to change the profile from offline to others it hang and restarts showing the offline while sim inserted!tried with different sim but no use.
How to remove the offline mode in nokia c7
You can get it back online by changing the profile to anything else other than Offline. To do this, briefly press the power button. This bring up a menu. Select another profile, say General.
There are also other reasons why your phone stays in Offline mode even when you do that. The most common of these would be a problem with your sim card.
Jan 04, 2012 • Cell Phones
2helpful
2answers
My nokia e72-1 went offline. How do i remove it from offline mode?
Hi
Thanks
I try different sim card but still its shows offline
just to confirm, is your profile setting set to 'offline', if yes please set to change another setting and see how it works.please let me know if you need additional help.
1helpful
NOkia C5 in offline mode. how to deactivate offline mode. Tried changing the profile.. but it says "Insert SIM"
if you hold finger on the volume up button dial a box comes up on the bottom of the screen says do you want to stay offline you press no and the phone will reboots itself into normal mode
2helpful
I buy new phone which is e72. then when i inserted my sim card one notification asking if i want to continue offline mode.. accidentally i click yes. after that my mobile always offline and cannot detected...
To resolve your problem,you just make a back-up all your files and after doing a back-up,reset your phone into factory default,this will erase all wrong setting.....
12helpful
3answers
How to remove offline mode in nokia e72 mobile
9helpful
2answers
How to make nokia off to online mode
just go to profile and select general, it will automatically put your device back to online
Nokia N72 Cellular Phone Logo
Top Nokia Cell Phones Experts
Ekse
Resolution IT Dubai
Resolution IT Dubai
Oloyede Monsuru
