Question about Homedics Shiatsu Massager
Hi, I have got brand new Homedics shistsu massager cushion (MCS-360H). When I am plugging it in, I can see that power button in the remote is not getting started. Can you please assist me with this problem. ideally when the power button is pressed from the remote, blue color light should be displayed (LED indicator) Please help. Thanks Medhavi
Glenn
    Master:
  • Homedics Master
  • 587 Answers
Hopefully you've got the right model listed here, as the MCS-360H is a Swedish Massage Cushion.
Did you remove the screw from the back of the unit before plugging it in...? The unit will not work properly until that screw is removed, and could be damaged if it is operated with the screw in place.
Here's the manual -
http://www.homedics.com//media/documents/homedics/instructionbooks/MCS-360H_IB.pdf
If removing that screw does not make the unit operate properly, contact Homedics Customer Service at 1-800-466-3342
Posted on Oct 03, 2017
4 Related Answers
Anonymous
  • 74 Answers
SOURCE: I have a Shiatsu Massaging
This link take you to Homedics web site...to the right of the picture you will see "Support Information" click that tab to download a useer manual....I hope this helps.
http://www.homedics.com/products/massage
Posted on Jan 07, 2009
Anonymous
  • 10 Answers
SOURCE: remote doesnot work
If you have not already, register your product with the company. And contact them regarding the malfunction. they should replace the part or the product if you send it in.
Posted on Jun 09, 2009
Anonymous
  • 35 Answers
SOURCE: how to replace power cord om homedics massager
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Posted on Sep 22, 2009
Anonymous
SOURCE: Wiring poitive and negative
Hi, I have an SBM 500H massage cushion without that AC-DC adaptor... may I know whats the working DC Voltage in Volts and DC Current in amps it works on? Kindly, email me at [email protected] Thanks!
Posted on Jan 04, 2010
HOW TO FIX smb400h homedics cushion
Hi
Kindly advise what is wrong with your cushion or kindly advise how your cushion is malfunctioning before i advise you further.We can order the necessary spares &repair.
Jul 05, 2014 | Homedics SBM 300H Therapist Select Shiatsu...
I've plug the 110-v Homedics massager into 220-v. It stopped working. Is there a fuse for this product?
The same case happned with me, I wrogly used it with 220V in India - my model is Homedics Shiatsu MCS-360H :-(
I can not see any thing burnt inside the chair ( I opened it and exmined ) but there is no light in attached remote - Kindly share the solution if you have any at [email protected]
Regards
Abhi
Jun 23, 2011 | Homedics Back Massager with Heat
Need a power adapter for the homedics sbm300 massager
No longer available from Homedics. Just called them today and found this out.
May 29, 2011 | Homedics SBM 300H Therapist Select Shiatsu...
I'm having a problem with my Homedics SBM 300H Massager. I was using it when it suddenly stopped, after hearing a faint "pop" sound from it. I tried re-plugging it in another outlet but still no...
Yes there was a short circuit and am sure the massager and the cpomputer where plugged in the sane extension box that was why there was loss of power when the massager stopped working.For the massager it is the fuse so get a new fuse for it.
Jan 21, 2011 | Homedics SBM 300H Therapist Select Shiatsu...
Massager squeaks
Zip off the cover and add some talcum powder to the inside cover where the roller make contact with the cover.
May 03, 2010 | Homedics SBM 300H Therapist Select Shiatsu...
Remote doesnot work
Jun 09, 2009 | Homedics Qrm 400h Therapist Select Quad...
Feb 04, 2009 | Homedics SBM 300H Therapist Select Shiatsu...
Homedics Shiatsu Massager Logo
117 people viewed this question
Top Homedics Health & Beauty Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
