Question about Freezers
How to set fridge temp - Freezers
Posted by sw_daleskinn on
Anonymous
  • 270 Answers
    1. The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food. Place your magnetic thermometer in the refrigerator.
    2. Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
    3. After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
    4. If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
    5. Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
    Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Posted on Dec 19, 2010
Freezer temp set at -4 but temp stays around 26
freezer section not working
get a fridge technician in to check / repair.
May 21, 2015 | Everest Refrigeration ETRF2 - Undercounter...
The indicator light (that usually reads temp) is flashing, food not frozen
check door seals
check power at plug
check thermostat setting in fridge the lower the number the colder the temperature
call a fridge technician
Apr 09, 2015 | Freezers
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
Igloo mini fridge not getting cold
The compressor may be frozen. Turn off the fridge for 6-8 hours, then turn it back on. Don't turn the temp to the coldest setting. If it will still not get cold, the compressor is probably bad.
Jan 22, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Zanussi refrigerator
make sure that the fridge temp control is not set too hi also check that the drain away at the back of the fridge is clear.
Thanks J
Jan 05, 2008 | Freezers
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Freezer Expert? Answer questions, earn points and help others
